hi. i've been working with the ethernet shield to make a web interface that can control several relays. I have followed all the steps here: Getting hands on Arduino Ethernet Shield - Do It Easy With ScienceProg
The web interface “hangs” and doesn’t load when I plug it up to an actual relay. However, everything loads fine when the relay is not plugged in. I am using the KTA-223 “relayduino” (KTA-223 USB/RS485 Relay IO Board - DEV-09526 - SparkFun Electronics) to control light bulbs via the same concept. Any help would be great.
#include <SPI.h>
#include <String.h>
#include <Ethernet.h>
Simple Ethernet Test
Arduino server outputs simple text to browser
The circuit:
* Arduino Duemilanove
* Arduino Ethernet shield
* Basic FTDI breakout 5V
*LED connected to GND and digital pin 4 via resistor
By Minde
http://www.sciencprog.com/
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192,168,0,2 };
byte gateway[] = { 192,168,0,1 };
byte subnet[] = { 255,255,255,0 };
//byte ip[] = { 216, 96, 251, 231 }; // ip in lan
//byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
//byte subnet[] = { 255, 255, 0, 0 }; //subnet mask
Server server(80); //server port
byte sampledata=50; //some sample data - outputs 2 (ascii = 50 DEC)
int ledPin = 4; // LED pin
char link[]="http://www.scienceprog.com/"; //link data
String readString = String(30); //string for fetching data from address
boolean LEDON = false; //LED status flag
void setup(){
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
//Set pin 4 to output
pinMode(ledPin, OUTPUT);
//enable serial datada print
void loop(){
// Create a client connection
Client client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 30)
//store characters to string
readString +=(c);
else{
readString = readString.substring(1); //push left
readString +=(c);
//output chars to serial port
Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
//lets check if LED should be lighted
if(readString.indexOf("L=1"))
//led has to be turned ON
digitalWrite(ledPin, HIGH); // set the LED on
LEDON = true;
}else{
//led has to be turned OFF
digitalWrite(ledPin, LOW); // set the LED OFF
LEDON = false;
// now output HTML data starting with standart header
client.println("Content-Type: text/html");
client.println();
//set background to yellow
client.print("<body style=background-color:yellow>");
//send first heading
client.println("<font color='red'><h1>HTTP test routines</font></h1>");
client.println("<hr />");
//output some sample data to browser
client.println("<font color='blue' size='5'>Sample data: ");
client.print(sampledata);//lets output some data
client.println("
");//some space between lines
//drawing simple table
client.println("<font color='green'>Simple table: ");
client.println("
client.println("<table border=1><tr><td>row 1, cell 1</td><td>row 1, cell 2</td></tr>");
client.println("<tr><td>row 2, cell 1</td><td>row 2, cell 2</td></tr></table>");
client.println("
//printing some link
client.println("<font color='blue' size='5'>Link: ");
client.print("<a href=");
client.print(link);
client.println(">Visit Scienceprog!</a>");
client.println("
//controlling led via checkbox
client.println("<h1>LED control</h1>");
//address will look like http://192.168.1.110/?L=1 when submited
client.println("<form method=get name=LED><input type=checkbox name=L value=1>LED
<input type=submit value=submit></form>");
client.println("
//printing LED status
client.print("<font size='5'>LED status: ");
if (LEDON)
client.println("<font color='green' size='5'>ON");
client.println("<font color='grey' size='5'>OFF");
client.println("</body></html>");
//clearing string for next read
readString="";
//stopping client
client.stop();
