Ethernet Shield: local vs internet http-requests
Hi all
I have setup an energy logger, reading an s0 output, using an interrupt.
During test i had a local apache/php/mysql server running, processing the http-requests from my Arduino.
This worked perfect, i did a http-req every minute and every entry was correctly logged.
Now, i switched the same code to my online server/database (same config) and i am experiencing the following:
But, when everything seems to go allright, some requests never reach my online server, i see a gap between the minutes.
When running everything on local network, i never had this.
My code below:
#include <SPI.h>
#include <Ethernet.h>
// Ethernet variables:
byte myMac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte myIp[] = {
  10, 0, 0, 13 };
byte myDns[] = {
  10, 0, 0, 1 };
byte myGateway[] = {
  10, 0, 0, 1 };
EthernetClient client;
char server[] = "myserver.com";
unsigned long lastConnectionTime = 0;
boolean lastConnected = false;
long postingInterval = 59380;
float KWh, Wh;
float timeBetweenPulses = 0;
float millisPrev = 0;
int s0state, s0statePrev;
float countPulses, countPulsesToSend;
boolean startRead;
String httpResponse;
// Setup:
  Serial.println("Start!");
  // disable w5100 SPI while starting SD
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  //Serial.println("SD: Starting..");
  //if(!SD.begin(4)) Serial.println("SD: Failed!"); // SD.begin() return with its SPI disabled, so nothing need to be done here.
  //else Serial.println("SD: Ok!");
  Serial.println("Ethernet: Starting...");
  //Ethernet.begin(mac, ip, dns, gateway, subnet);
  Ethernet.begin(myMac, myIp, myDns, myGateway);
  Serial.print("Ethernet: IP address: ");
  Serial.println(Ethernet.localIP());
  // Ethernet begin returns with its SPI enabled, so disable it.
  pinMode(2,INPUT);
  digitalWrite(2,HIGH);
  attachInterrupt(0, pulse, RISING);
// Loop:
  if(client.available()){
    httpResponse = "";
    while (client.available() > 0) {
      char c = client.read();
      if (c == '[' ) { //'<' is our begining character
        startRead = true; //Ready to start reading the part
        c = client.read();
      if(startRead){
        if(c != ']'){ //'>' is our ending character
          httpResponse += c;
        else{
          //got what we need here! We can disconnect now
          startRead = false;
    if(httpResponse == "1"){
      Serial.print("EthernetClient: ACK Received, ");
      Serial.print(countPulsesToSend);
      Serial.println(" pulses sent. Resetting \'countPulsesToSend\'...");
      countPulsesToSend = 0;
      disconnect();
    else{
      Serial.println("EthernetClient: FAILED ACK Received, pulses NOT sent. NOT resetting \'countPulsesToSend\'...");
      disconnect();
  if(millis() - lastConnectionTime > postingInterval){
    timeBetweenPulses = (millis() - millisPrev)/ 1000;
    millisPrev = millis();
    Wh = countPulsesToSend * 1.25 / timeBetweenPulses * 3600;
    KWh = (float)countPulses / 800;
    Serial.print("KWh measurement: ");
    Serial.print(timeBetweenPulses);
    Serial.print(" s / ");
    Serial.print("Total: ");
    Serial.print(countPulses);
    Serial.print(" pulses / ");
    Serial.print("To send: ");
    Serial.print(KWh);
    Serial.print(" KWh / ");
    Serial.print(Wh);
    Serial.println(" W");
    httpRequest();
    lastConnectionTime = millis();
void pulse(){
  countPulses ++;
  countPulsesToSend ++;
void disconnect(){
  client.flush();
  client.stop();
  Serial.println("EthernetClient: Disconnecting...");
  while(client.connected()) {
    client.flush();
    client.stop();
    Serial.println("EthernetClient: client.stop()");
void httpRequest() {
  // Send data to webserver:
  if (client.connect(server, 80)) {
    //Serial.print("*** countPulsesToSend: ");
    //Serial.println(countPulsesToSend);
    //client.print("GET http://10.0.0.2/storekwh/value=");
    client.print("GET http://myserver.com/storekwh/value=");
    client.print(countPulsesToSend);
    client.print("/key=www/");
    client.println(" HTTP/1.1");
    //client.println("Host: 10.0.0.2");
    client.println("Host: myserver.com");
    client.println("User-Agent: arduino-ethernet");
    client.println("Connection: close");
    client.println();
    //countPulsesToSend = 0;
  else {
    // if you couldn't make a connection:
    Serial.println("EthernetClient: Connection failed!");
    disconnect();
I use this with good results. It downloads the Google home page every 10 seconds. I recommend trying it with your server. Download a simple html doc at first to see if it is working ok. If that does ok, then try the php page.
