ethernet shield module w5100
I just bought an Ethernet shield module W5100 and am using it with Arduino Uno R3(Atmega 16U2)
the Ethernet shield didn’t cam with any MAC Add, so I give it one.
After setting the IP add, am able to ping the Ethernet shield by I get get it in browser.
What’s the use of the server port?
here’s the code :
Home Automation Created By Bn4al 01/06/2016
#include <SPI.h>
#include <Ethernet.h>
EthernetServer server(80);// Server port
const byte lightPin = 5;// Select pin for Light
const byte FanPin = 6;// Select pin for Fan
const byte LampPin = 7;// Select pin for Lamp
const byte AlarmPin = 8;// Select pin for Alarm
const byte WaterPumpPin = 9;// Select pin for WaterPump
const byte ChandellierPin = 10;// Select pin for Chandellier
const byte CeilingPin = 11;// Select pin for Ceiling
const byte AuxillaryPin = 12;// Select pin for Auxillary
byte mac = { 0x00, 0x08, 0xDC, 0xAB, 0xCD, 0xEF };// Physical MAC address
byte ip = { 192, 168, 100, 25 };// Fixed IP address
byte gateway = { 192, 168, 100, 1 };// Router Gateway Internet access
byte subnet = { 255, 255, 255, 0 };// Subnet mask
String readString;
delay(300);// Delay for Ethernet shield initialization (Arduino has 65mS Power Up delay and W5100 reset logic has 280mS)
pinMode(lightPin, OUTPUT);// Define pin for Light as output
pinMode(FanPin, OUTPUT);// Define pin for Fan as Output
pinMode(LampPin, OUTPUT);// Define pin for Lamp as Output
pinMode(AlarmPin, OUTPUT);// Define pin for Alarm
pinMode(WaterPumpPin, OUTPUT);// Define pin for WaterPump
pinMode(ChandellierPin, OUTPUT);// Define pin for Chandellier
pinMode(CeilingPin, OUTPUT);// Define pin for Ceiling
pinMode(AuxillaryPin, OUTPUT);// Define pin for Auxillary
Serial.begin(9600);// Initialize serial communications at 9600 bps
Serial.println(F(“Home Automation”));// Display Arduino title
Ethernet.begin(mac, ip, gateway, subnet);// Start Ethernet
server.begin();
Serial.print(F(“System initialized. Local IP address is:”));
Serial.println(Ethernet.localIP());// Print Server IP address
EthernetClient client = server.available();// Create a client connection
if (client == true)
while (client.connected())
if (client.available())
char c = client.read();// Read char by char HTTP request
if (readString.length() < 100)
readString = readString + c;// Store characters to string
if (c == ‘\n’)
Serial.println(readString);
client.println(F(“http/1.1 200 ok”));// Send standard http headers
client.println(F(“content-type: text/html”));
client.println();
client.println(F("<!doctype html>"));
client.println(F(""));
client.println(F(“Home Automation”));
client.println(F(“
Home Automation
client.println(F("Bn4al
client.println(F("LOGO"));
client.println(F("
Click the Buttons to turn On and OFF
client.print(F("<input type=button value=‘Light ON’ style=‘width:120px;’ onmousedown=location.href=’/?ML_on’>"));
client.println(F("<input type=button value=‘Light OFF’ style=‘width:120px;’ onmousedown=location.href=’/?ML_off’>
client.print(F("<input type=button value=‘Fan ON’ style=‘width:120px;’ onmousedown=location.href=’/?FN_on’>"));
client.println(F("<input type=button value=‘Fan OFF’ style=‘width:120px;’ onmousedown=location.href=’/?FN_off’>
client.print(F("<input type=button value=‘Lamp ON’ style=‘width:120px;’ onmousedown=location.href=’/?LM_on’>"));
client.println(F("<input type=button value=‘Lamp OFF’ style=‘width:120px;’ onmousedown=location.href=’/?LM_off’>
client.print(F("<input type=button value=‘Alarm ON’ style=‘width:120px;’ onmousedown=location.href=’/?AL_on’>"));
client.println(F("<input type=button value=‘Alarm OFF’ style=‘width:120px;’ onmousedown=location.href=’/?AL_off’>
client.print(F("<input type=button value=‘WaterPump ON’ style=‘width:120px;’ onmousedown=location.href=’/?WP_on’>"));
client.println(F("<input type=button value=‘WaterPump OFF’ style=‘width:120px;’ onmousedown=location.href=’/?WP_off’>
client.print(F("<input type=button value=‘Chandellier ON’ style=‘width:120px;’ onmousedown=location.href=’/?CH_on’>"));
client.println(F("<input type=button value=‘Chandellier OFF’ style=‘width:120px;’ onmousedown=location.href=’/?CH_off’>
client.print(F("<input type=button value=‘Ceiling ON’ style=‘width:120px;’ onmousedown=location.href=’/?CL_on’>"));
client.println(F("<input type=button value=‘Ceiling OFF’ style=‘width:120px;’ onmousedown=location.href=’/?CL_off’>
client.print(F("<input type=button value=‘Auxillary ON’ style=‘width:120px;’ onmousedown=location.href=’/?AU_on’>"));
client.println(F("<input type=button value=‘Auxillary OFF’ style=‘width:120px;’ onmousedown=location.href=’/?AU_off’>
delay(1);// Page loading delay
client.stop();// Stopping client
if(readString.indexOf("/?ML_on") > 0) digitalWrite(lightPin, HIGH);// Switch on Light
if(readString.indexOf("/?ML_off") > 0) digitalWrite(lightPin, LOW);// Switch off Light
if(readString.indexOf("/?FN_on") > 0) digitalWrite(FanPin, HIGH);// Switch on Fan
if(readString.indexOf("/?FN_off") > 0) digitalWrite(FanPin, LOW);// Switch off Fan
if(readString.indexOf("/?LM_on") > 0) digitalWrite(LampPin, HIGH);// Switch on Lamp
if(readString.indexOf("/?LM_off") > 0) digitalWrite(LampPin, LOW);// Switch off Lamp
if(readString.indexOf("/?AL_on") > 0) digitalWrite(AlarmPin, HIGH);// Switch on Alarm
if(readString.indexOf("/?AL_off") > 0) digitalWrite(AlarmPin, LOW);// Switch off Alarm
if(readString.indexOf("/?WP_on") > 0) digitalWrite(WaterPumpPin, HIGH);// Switch on WaterPump
if(readString.indexOf("/?WP_off") > 0) digitalWrite(WaterPumpPin, LOW);// Switch off WaterPump
if(readString.indexOf("/?CH_on") > 0) digitalWrite(ChandellierPin, HIGH);// Switch on Chandellier
if(readString.indexOf("/?CH_off") > 0) digitalWrite(ChandellierPin, LOW);// Switch off Chandellier
if(readString.indexOf("/?CL_on") > 0) digitalWrite(CeilingPin, HIGH);// Switch on Ceiling
if(readString.indexOf("/?CL_off") > 0) digitalWrite(CeilingPin, LOW);// Switch off Ceiling
if(readString.indexOf("/?AU_on") > 0) digitalWrite(AuxillaryPin, HIGH);// Switch on Auxilary
if(readString.indexOf("/?AU_off") > 0) digitalWrite(AuxillaryPin, LOW);// Switch off Auxilary
readString = “”;// Clearing string for next read
}// End of line reached
}// End of client available
}// End of client connected
}// End of client connection
}// End of loop
thanks,
Bn4al
First off I recommend you use code tags to post code cos somebody gonna get a little p1ssy about it LOL
Second you can find the MAC by looking at the items connected to your router. Go to your router setup page. (usually under DHCP) or use some other software to look for the MAC. They tend to be fixed but there are methods to spoof them. Try the "real" MAC in place of your made up one.
Server ports have different functions depending on what you want to do. There are also many ways of talking to servers. If its just serving up a simple web page for you to browse values sent from the Arduino then all you need to do is browse to the IP address. If its a little more interactive then you may also be able to enter and change values. Sometimes via the address bar or maybe even using a mouse.
There are COMMON ports depending on what you want to actually do. "listed here"
General rule is don't mix up what you want to do with a port that has a function your network may depend on. EG dont use a timekeeping port for a web browsing port. Randomly defining a server port could take other things on your network offline or unable to function properly.
First off, this is incorrect. There is a parameter missing. I'll use the gateway for the DHCP server.
// change this
// to this
  Ethernet.begin(mac, ip, gateway, gateway, subnet);// Start Ethernet
There is no "real MAC" for the ethernet shield. If the ethernet shield came with a MAC address, use it. If not, use DEAD BEEF FEED. The router's DHCP or ARP table will show whatever you use.
Ballscrewbob covered the port thing.
Hi, I finally have been able to make it work with the following codes :
Created by Bn4al
#include <SPI.h>
#include <Servo.h>
int led1 = 5;
int led2 = 6;
int led3 = 8;
int led4 = 9;
int led5 = 4;
int led6 = 3;
int led7 = 2;
Servo microservo;
int pos = 0;
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip = { 192, 168, 100, 25 }; // ip in lan
byte gateway = { 192, 168, 100, 1 }; // internet access via router
byte subnet = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
pinMode(led7, OUTPUT);
microservo.attach(7);
// start the Ethernet connection and the server:
server.begin();
Serial.print("server is at ");
if (client) {
while (client.connected()) {
if (client.available()) {
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == ‘\n’) {
Serial.println(readString); //print to serial monitor for debuging
client.println(“HTTP/1.1 200 OK”); //send new page
client.println(“Content-Type: text/html”);
client.println();
client.println("");
client.println("");
client.println("");
client.println("");
client.println("");
client.println(“Genesis Home Automation”);
client.println("");
client.println("");
client.println(“
Home Automation
client.println(“
Home Control System
int sensorReading = analogRead(A4);
float temperature = (sensorReading5100) / 1024;
client.print("
client.print(“Room Temperature: “);
client.print(temperature);
client.print(” C”);
client.println("
client.println(”<a href="/?button1on"">Light ON");
client.println("<a href="/?button1off"">Light OFF
client.println(”
client.println(”
client.println(”<a href="/?button3on"">FAN ON");
client.println("<a href="/?button3off"">FAN OFF
client.println(”
client.println(”
client.println(”<a href="/?button4on"">lamp ON");
client.println("<a href="/?button4off"">Lamp OFF
client.println(”
client.println(”
client.println(”<a href="/?button6on"">Pump ON");
client.println("<a href="/?button6off"">Pump OFF
client.println(”
client.println(”
client.println(”<a href="/?button7on"">Alarm ON");
client.println("<a href="/?button7off"">Alarm OFF
client.println(”
client.println(”
client.println(”<a href="/?button8on"">lamp3 ON");
client.println("<a href="/?button8off"">Lamp3 OFF
client.println(”
client.println(”
client.println(”<a href="/?button9on"">lamp4 ON");
client.println("<a href="/?button9off"">Lamp4 OFF
client.println(”
client.println(”
client.println(“
Created by Bn4al
client.println(”
client.println(”");
client.println("");
delay(1);
//stopping client
client.stop();
//controls the Arduino if you press the buttons
if (readString.indexOf("?button1on") >0){
digitalWrite(led1, HIGH);
if (readString.indexOf("?button1off") >0){
digitalWrite(led1, LOW);
if (readString.indexOf("?button3on") >0){
digitalWrite(led2, HIGH);
if (readString.indexOf("?button3off") >0){
digitalWrite(led2, LOW);
if (readString.indexOf("?button4on") >0){
digitalWrite(led3, HIGH);
if (readString.indexOf("?button4off") >0){
digitalWrite(led3, LOW);
if (readString.indexOf("?button6on") >0){
digitalWrite(led4, HIGH);
if (readString.indexOf("?button6off") >0){
digitalWrite(led4, LOW);
if (readString.indexOf("?button7on") >0){
digitalWrite(led5, HIGH);
if (readString.indexOf("?button7off") >0){
digitalWrite(led5, LOW);
if (readString.indexOf("?button8on") >0){
digitalWrite(led6, HIGH);
if (readString.indexOf("?button8off") >0){
digitalWrite(led6, LOW);
if (readString.indexOf("?button9on") >0){
digitalWrite(led7, HIGH);
if (readString.indexOf("?button9off") >0){
digitalWrite(led7, LOW);
if (readString.indexOf("?button2on") >0){
for(pos = 0; pos < 180; pos += 3) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
microservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(15); // waits 15ms for the servo to reach the position
if (readString.indexOf("?button2off") >0){
for(pos = 180; pos>=1; pos-=3) // goes from 180 degrees to 0 degrees
//clearing string for next read
readString="";
OMG…please use CODE TAGS.
its the one that looks like “</>” on the small toolbar just above the smileys.
Maybe go practice that one please
Or even use the function in the IDE in the EDIT section called “Copy for Forum”
Once is an easy mistake second time would indicate a distinct lack of attention on your part.
OK so a new set of code works.
Great so whats the question ?
