Hi there,
I have an Uno with Ethernet shield, both from a Sparkfun kit. I have the Ethernet shield connected through my macbook's wifi.
When I enabled internet sharing on the laptop and fire up the Arduino, I get an IP, it connects and pulls the file I need via HTTP. However, if I reset the Arduino, it keeps it's IP address but will not connect to any outside servers. If I reset the internet sharing and the Arduino, it comes back.
I originally saw this when using my Squeezebox as a bridge and switched over to the MacBook. I also tried this on two different generations of MacBooks with the same results.
Has anyone else had similar experiences? Any recommendations?
Thanks.
-P.
Update: I tried to specify the IP, gateway, etc. with the same outcome. It connects on the first go, but then not again. Using Wireshark, I took a look at the packets. The SYN is being sent to the remote server, with the correct gateway header. However, nothing is making it back. I would think this a Mac issue, except I saw the same with my Squeezebox.
