Ethernet shield not sending the POST request to webserver
I am sending some data by post request to my webserver using ethernet shield and uno. But ethernet shield is connecting to the server but not sending the post request. Can anyone help me to do that?
here is my code
#include <Ethernet.h>
#include <SPI.h>
//byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x01 }; // RESERVED MAC ADDRESS
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetClient client;
int t = 0;	// TEMPERATURE VAR
int h = 0;	// HUMIDITY VAR
String data;
	if (Ethernet.begin(mac) == 0) {
		Serial.println("Failed to configure Ethernet using DHCP");
 else{
      Serial.print("  DHCP assigned IP ");
      Serial.println(Ethernet.localIP());
	h = 7;
	t = 6;
	data = "";
//  if (client.connect("www.fibrous-health.000webhostapp.com",80)) { // REPLACE WITH YOUR SERVER ADDRESS
//    Serial.print("connected to ");
//    Serial.println(client.remoteIP());
// else{
//  Serial.print("Not Connected");
char server[] = "www.fibrous-health.000webhostapp.com";
void loop(){
	data = String("temp1=") + t + "&hum1=" + h;
  Serial.print("connected \n");
    // Make a HTTP request:
    Serial.print("Making a HTTP request \n");
    client.println("POST /add.php HTTP/1.1");
    client.println("Host: www.fibrous-health.000webhostapp.com");
    client.println("Content-Type: application/x-www-form-urlencoded");
    client.println("Connection: close");
    client.println("User-Agent: Arduino/1.0");
    client.print("Content-Length: ");
    client.println(data.length());
    client.println();
    client.print(data);
    client.println();
    Serial.print(data+"\n");
    Serial.print("Data sent... \n");
 else{
  Serial.print("Not Connected \n");
	if (client.connected()) {
		client.stop();	// DISCONNECT FROM THE SERVER
	delay(3000); // WAIT FIVE MINUTES BEFORE SENDING AGAIN
and here is my add.php file code
<?php
   	include 'connect.php';
   	$link=Connection();
     	$temp1=$_POST["temp1"];
	    $hum1=$_POST["hum1"];
	$sql = "INSERT INTO `templog` (`temperature`, `humidity`)
		VALUES ('".$temp1."','".$hum1."')";
   	if (mysqli_query($link, $sql)) {
   	    echo "New record created successfully";
   	    echo "Error: " . $sql . "
" . mysqli_error($link);
	mysqli_close($link);
  	//header("Location: index.php");
when i send the post request from a different source likehttps://www.codepunker.com/tools/http-requests it worked but from arduino it did not. any kind of help will appreciated
Look at the ethernet client example - it ends with two println statements which, IIRC, is important.
Also, what do your server logs say?
You have to use this library;
"#include <Ethernet2.h>"
Had you test your API through Rest Client? if it give proper response to your request then there is no error on your server side code.
you should review your arduino code.
I think problem in your json formate.
you data variable is :
here t & h have int datatype.
you should change it into
data = "temp1=" + (String)t + "&hum1=" + (String)h;
now this is proper string. you can try this.
