Hi
I have received today another brand new Arduino Ethernet Shield.
I ordered a new one as I thought the old one was broken, but the new one does exactly the same.
Following many many many examples, tutorials and suggestions I am left still with no luck.
What I have done:
- Attach shield to my Uno matching the pins between the main board and shield
- Power the Uno by USB
- Take the ready made example (version 1.0.6) from the library. The one I am trying is "Ethernet> Web Server"
- Changed the IP Address
- Added { pinMode(4, OUTPUT); digitalWrite(4, HIGH);} to setup() as per other suggestions
- Added a delay between init of Serial and Ethernet as per other forum suggestion
- Added a delay after Ethernet.begin as per other forum suggestion
What I have is a board on which the Ethernet Port Green LED flashes continuously. The Orange LED does not light up. On the top of the shield board the PWR LED is red and lit, the LINK, 100M and FULLD LED's flash continuously.
The setup () routine ends with the message as per the sketch (server is at ....)
And then NOTHING.
Can't ping it, can't connect to it, ......
Some sites suggest removing soldering from between pins, which I tried on the first board to no avail and frankly I don;t believe that the manufacturing is so bad that they would mess up different boards on exactly the same place for so long without fixing it.
So now I am asking if anyone can help me please..
OK, so after reading yet another forum topic, I thought to try connecting the shield to my laptop direct using a cross-over cable.
It seems to work now.
Can anyone explain why connecting it with a straight connector (UTP) via a stock standard Netgear unmanaged switch would not work?
Thanks in advance
Paul
Very simple client test code you can try unmodified to see if you can get a response from the server.
//zoomkat 3-1-13
//simple client checkip test
//for use with IDE 1.0.1 or later
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // test web page server
EthernetClient client;
void setup(){
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
while(true);
Serial.println("Better client ip test 3/1/13"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(serverName, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET / HTTP/1.0"); //download text
client.println("Host: checkip.dyndns.com");
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
Serial.print(c); //prints byte to serial monitor
Serial.println("disconnecting.");
Serial.println("==================");
client.stop(); //stop client
