ethernet shield problem
Hi all i have a problem with the Ethernet shield.
this is the sketch i have wrote // --------------------------------------------------------- void loop() { wdt_reset ();
EthernetClient client = server.available(); if (client) { wdt_reset (); if (client.available() > 0) { char thisChar = client.read(); Serial.write(thisChar); RXtext +=thisChar; // --------------------- this one repeat for few other strings ---- if (RXtext.indexOf("L1_On")>=0){ // do stuff RXtext = GetStat(); // get system status and replay server.print(RXtext); Serial.println(RXtext); RXtext = "";
wdt_reset (); } // ---------- end of repeat ------- } } //-------------------------------------------------------------------------------
for some reason the arduino gets stuck after few times i connect to it it does not resets the wtd and it gets reset and the it looses the ip and gets 255.255.255.255 ip
can someone tell me what is the peoblem?
Why do you need the watch dog reset?
Why are you still using the String class? It has known, well-documented, problems. Quit shooting yourself in the foot. Get rid of it.
PaulS: Why do you need the watch dog reset?
I'm using the watch dog to make sure it's still running
what should i use instead of String?
Fixing the problems that are causing it to stop working is almost always a better idea.
Null-terminated arrays of chars, also known as strings. Which are not the same thing as Strings.
danhajduk: what should i use instead of String?
A character array. Here is my server code. It does not use String types, and closes the connection when finished sending packets. You may also be running out of sockets. There are only 4. http://playground.arduino.cc/Code/WebServerST
Client test code you can try:
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "web.comporium.net"; // zoomkat's test web page server
EthernetClient client;
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text
    client.println("Host: web.comporium.net");
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
