Ethernet Shield problem
Hello everyone. I have an Arduino Uno and recently i got an thernet shield ENC28J60 from www.ekitszone.com. My proble is that i cant make it work...
I used this code below:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,2,2);
 // disable SD card if one in the slot
 pinMode(4,OUTPUT);
 digitalWrite(4,HIGH);
 Serial.println("Starting w5100");
 Ethernet.begin(mac,ip);
 Serial.println(Ethernet.localIP());
and my result is 0.0.0.0
I can't assign an ip nor with dhcp neither with static. can you help me please?
You are using the library for the w5100 ethernet shield. You need to install the ENC28J60 library.
Thanks a lot. I will try it later
