Ethernet Shield Problem!
Hi all,
I have a strange issue with my setup: arduino uno + ethernet shield (+a couple of sensors like pir, temp and 2 relays). It has been working ok for a year or two, but during the past 2 weeks ethernet connection randomly stops (after a couple of hours and sometimes after a couple of days). The arduino continues to work (i have led that flashes when the loop starts and when it ends) but the ethernet shield stops ( i cannot ping it and it does not receive commands). In order to fix the problem i have to re-plug the ethernet cable). Has anyone experienced smt similar before? Any suggestions on how to fix it?
Thanks!
If the ONLY thing you do is unplug the ethernet cable and then plug it back in, you have a bad cable or a worn out connector.
I have tried various solutions like changing the power supply, the wiring, lan configuration, changed the sketch, and yesterday the ethernet cable. So far it works ok (15hours have passed) but i`m not very optimistic about it! Guess I have to wait!
So after changing the cable arduino worked ok for 2.5 days, then it did the same thing, but i could not fix it by just removing the ethernet cable, i had to power it off. I`m guessing there is a problem with the ethernet shield so i ordered a new one!
