ethernet shield R3 question
hello. im trying to make a file server using an arduino and ethernet shield based on this
http://www.ladyada.net/learn/arduino/ethfiles.html
it can display text files, but is there a way for this or the official ethernet library to make a mp3 file host for my network?
Instead of "Content-Type: text/html" you'd use "Content-Type: audio/x-mpeg".
did that it half worked. when i loaded up the ip i got no files but a corrupted quicktime file
heres the code
 * USERS OF ARDUINO 0023 AND EARLIER: use the 'SDWebBrowse.pde' sketch...
 * 'SDWebBrowse.ino' can be ignored.
 * USERS OF ARDUINO 1.0 AND LATER: **DELETE** the 'SDWebBrowse.pde' sketch
 * and use ONLY the 'SDWebBrowse.ino' file.  By default, BOTH files will
 * load when using the Sketchbook menu, and the .pde version will cause
 * compiler errors in 1.0.  Delete the .pde, then load the sketch.
 * I can't explain WHY this is necessary, but something among the various
 * libraries here appears to be wreaking inexplicable havoc with the
 * 'ARDUINO' definition, making the usual version test unusable (BOTH
 * cases evaluate as true).  FML.
 * This sketch uses the microSD card slot on the Arduino Ethernet shield
 * to serve up files over a very minimal browsing interface
 * Some code is from Bill Greiman's SdFatLib examples, some is from the
 * Arduino Ethernet WebServer example and the rest is from Limor Fried
 * (Adafruit) so its probably under GPL
 * Tutorial is at http://www.ladyada.net/learn/arduino/ethfiles.html
 * Pull requests should go to http://github.com/adafruit/SDWebBrowse
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
#include <SPI.h>
/************ ETHERNET STUFF ************/
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 123 };
EthernetServer server(80);
/************ SDCARD STUFF ************/
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
  PgmPrint("error: ");
  SerialPrintln_P(str);
  if (card.errorCode()) {
    PgmPrint("SD error: ");
    Serial.print(card.errorCode(), HEX);
    Serial.print(',');
    Serial.println(card.errorData(), HEX);
  while(1);
  PgmPrint("Free RAM: ");
  Serial.println(FreeRam());
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
  // breadboards.  use SPI_FULL_SPEED for better performance.
  pinMode(10, OUTPUT);                       // set the SS pin as an output (necessary!)
  digitalWrite(10, HIGH);                    // but turn off the W5100 chip!
  if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
  // initialize a FAT volume
  if (!volume.init(&card)) error("vol.init failed!");
  PgmPrint("Volume is FAT");
  Serial.println(volume.fatType(),DEC);
  if (!root.openRoot(&volume)) error("openRoot failed");
  // list file in root with date and size
  PgmPrintln("Files found in root:");
  root.ls(LS_DATE | LS_SIZE);
  // Recursive list of all directories
  PgmPrintln("Files found in all dirs:");
  root.ls(LS_R);
  PgmPrintln("Done");
  // Debugging complete, we start the server!
  Ethernet.begin(mac, ip);
  server.begin();
void ListFiles(EthernetClient client, uint8_t flags) {
  // This code is just copied from SdFile.cpp in the SDFat library
  // and tweaked to print to the client output in html!
  dir_t p;
  root.rewind();
  client.println("<ul>");
  while (root.readDir(p) > 0) {
    // done if past last used entry
    if (p.name[0] == DIR_NAME_FREE) break;
    // skip deleted entry and entries for . and  ..
    if (p.name[0] == DIR_NAME_DELETED || p.name[0] == '.') continue;
    // only list subdirectories and files
    if (!DIR_IS_FILE_OR_SUBDIR(&p)) continue;
    // print any indent spaces
    client.print("<li><a href=\"");
    for (uint8_t i = 0; i < 11; i++) {
      if (p.name[i] == ' ') continue;
      if (i == 8) {
        client.print('.');
      client.print((char)p.name[i]);
    client.print("\">");
    // print file name with possible blank fill
      if (i == 8) {
        client.print('.');
    client.print("</a>");
    if (DIR_IS_SUBDIR(&p)) {
      client.print('/');
    // print modify date/time if requested
    if (flags & LS_DATE) {
       root.printFatDate(p.lastWriteDate);
       client.print(' ');
       root.printFatTime(p.lastWriteTime);
    // print size if requested
    if (!DIR_IS_SUBDIR(&p) && (flags & LS_SIZE)) {
      client.print(' ');
      client.print(p.fileSize);
    client.println("</li>");
  client.println("</ul>");
// How big our line buffer should be. 100 is plenty!
#define BUFSIZ 100
  char clientline[BUFSIZ];
  int index = 0;
  if (client) {
    // an http request ends with a blank line
    boolean current_line_is_blank = true;
    // reset the input buffer
    index = 0;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // If it isn't a new line, add the character to the buffer
        if (c != '\n' && c != '\r') {
          clientline[index] = c;
          index++;
          // are we too big for the buffer? start tossing out data
          if (index >= BUFSIZ)
            index = BUFSIZ -1;
          // continue to read more data!
          continue;
        // got a \n or \r new line, which means the string is done
        clientline[index] = 0;
        // Print it out for debugging
        Serial.println(clientline);
        // Look for substring such as a request to get the root file
        if (strstr(clientline, "GET / ") != 0) {
          // send a standard http response header
          client.println("Content-Type: text/html, audio/x-mpeg");
          client.println();
          // print all the files, use a helper to keep it clean
          client.println("<h2>Files:</h2>");
          ListFiles(client, LS_SIZE);
        } else if (strstr(clientline, "GET /") != 0) {
          // this time no space after the /, so a sub-file!
          char *filename;
          filename = clientline + 5; // look after the "GET /" (5 chars)
          // a little trick, look for the " HTTP/1.1" string and
          // turn the first character of the substring into a 0 to clear it out.
          (strstr(clientline, " HTTP"))[0] = 0;
          // print the file we want
          Serial.println(filename);
          if (! file.open(&root, filename, O_READ)) {
            client.println("HTTP/1.1 404 Not Found");
            client.println();
            client.println("<h2>File Not Found!</h2>");
          Serial.println("Opened!");
          client.println();
          int16_t c;
          while ((c = file.read()) > 0) {
              // uncomment the serial to debug (slow!)
              //Serial.print((char)c);
              client.print((char)c);
          file.close();
          // everything else is a 404
          client.println("Content-Type: audio/x-mpeg");
          client.println();
    // give the web browser time to receive the data
    delay(1);
    client.stop();
a file called 1.mp3 was on the sdcard
The print() methods are for sending ASCII data. The write() methods are for sending binary data. I wonder which you should be using, seeing as how you are sending binary data.
You should decide which type you're feeding, you cannot feed both (text and mp3s). So it's
client.println("Content-Type: text/html");
OR
You cannot do both at the same time.
here is what the serial monitor says
Free RAM: 784
Volume is FAT16
TEST/ 2012-07-17 22:26:40
BNL_WI~1.MP3 2012-05-26 20:28:54 4285044
TEST/
10WHON~1.MP3
BNL_WI~1.MP3
Done
GET / HTTP/1.1
GET /favicon.ico HTTP/1.1
favicon.ico
plus i cannot click on my folder in there
updated code is getting there. the file opens but still favicon.
#include <SdFat.h>
#include <SPI.h>
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
    Serial.print(',');
  while(1);
  root.ls(LS_R);
  PgmPrintln("Done");
  server.begin();
  dir_t p;
  root.rewind();
      if (i == 8) {
        client.print('.');
      if (i == 8) {
        client.print('.');
      client.print('/');
       client.print(' ');
      client.print(' ');
#define BUFSIZ 100
  int index = 0;
  if (client) {
    index = 0;
          index++;
            index = BUFSIZ -1;
          continue;
          client.println();
          client.println("<h2>Arduino File Host:</h2>");
          char *filename;
            client.println();
          client.println();
          int16_t c;
              Serial.write((char)c);
              client.write((char)c);
          file.close();
          client.println();
    delay(1);
    client.stop();
Free RAM: 810
Volume is FAT16
TEST/
10WHON~1.MP3
BNL_WI~1.MP3
Done
GET /TEST HTTP/1.1
TEST
Opened!
. GET /favicon.ico HTTP/1.1
favicon.ico
GET / HTTP/1.1
favicon.ico
GET /BNL_WI~1.MP3 HTTP/1.1
BNL_WI~1.MP3
Opened!
ÿûGET /favicon.ico HTTP/1.1
favicon.ico
it thinks the folder is a file
tweaked a little and still no work
