Ethernet Shield SD Card Pins (Mega) ?
Sorry if this has been asked before.
I have an Ethernet Shield purchased on eBay supposedly Mega compatible.
I am trying to access the SD card to noavail.
The Shield details are:
HanRun HR911105A 10/49 mounted on an Arduino Mega 2560
I tried the standard ReadCardInfo sketch.
Default setting. Generates standard "Is card initialized etc"
Changed pins according to sketch, but still same errors.
Reformatted card to FAT32 still same.
Am using 2GB card.
As these shields are selling like hot cakes on eBay I am hoping someone has the correct pins worked out?
If so any help would be appreciated?
Thanks and kind regards,
jB 8)
Post a link to the eBay site page where they are "selling like hot cakes". There are a few types of ethernet shields, and each are different.
This is not a formatting problem. It is a basic I/O problem.
Don't format cards 2GB or less as FAT32. The SD standard requires small cards to be FAT16. Use this formatter to get the correct standard format https://www.sdcard.org/downloads/formatter_3/.
Once again you must solve the basic I/O problem before formatting will help.
Here is an example of what I have got.
http://www.ebay.co.uk/itm/Ethernet-Shield-W5100-For-Arduino-2009-UNO-Mega-1280-2560-/300695278167?pt=UK_Sound_Vision_Other&hash=item4602d5d257
Thanks
jB 8)
When you upload the CardInfo sketch, you get this on the serial monitor?
Initializing SD card...initialization failed. Things to check:
  • is a card is inserted?
  • Is your wiring correct?
  • did you change the chipSelect pin to match your shield or module?
Then in the CardInfo code:
  // after this in setup()
  pinMode(10, OUTPUT);     // don't change this to 53 on a mega
  // add this
  digitalWrite(10,HIGH);
After that change, I get:
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Volume type is FAT32
Volume size (bytes): 4115660800
Volume size (Kbytes): 4019200
Volume size (Mbytes): 3925
Files found on the card (name, date and size in bytes):
TEST.TXT 2000-01-01 01:00:00 20
TESTFILE.TXT 2000-01-01 01:00:00 29
Thank you very much...
Kind regards,
jB
