I try to hook up a servo to an ethernet shield because I want to control the servo with an textfield over the internet. Since I am new to the ethernet shield I still have some problems regarding the code.
I manage to put up a string i.e. 192.168.0.3/?servo=123 by using the GET command but I have some problems reading it with the arduino and put it in an int. In the end I want the arduino to read sthg like: int servo = 123 which i can send to the servo. Is there any easy way to do this?
I was also thinking of some read command which searches the readString for “?servo=” and puts whatever comes afterwards in a special variable. do you know any special command for this? After this I also want to light an LED while doing this so dont mind the LED parts.
Thanks in advance!
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
byte mac[] = { 0x54, 0x55, 0x58, 0x10, 0x00, 0x24 };
byte ip[] = { 192, 168, 0, 3 };
byte subnet[] = { 255, 255, 255, 0 };
EthernetServer server(80);
Servo myservo;
int Pin3 = 3;
char Data[4];
int i;
int x;
int servo;
String readString=String(100); // string for fetching data from address
void setup(){
Ethernet.begin(mac, ip, subnet);
server.begin();
myservo.attach(9);
pinMode(Pin3, OUTPUT);
Serial.begin(9600); }
void loop(){
if (client)
while (client.connected())
if (client.available())
char c = client.read();
if (readString.length() < 100) {readString = readString + c;}
if (c == '\n')
Serial.print(readString); //I get something like "100GET ?servo=xxx" Where does the 100 come from?
do {
if(readString>0)
{ Data[x] = readString[x+13]; i++; } //Problem is probably here! :)
while(x<4);
x=0;
servo = atof(Data);
Serial.print("Received: ");
Serial.print(servo);
myservo.writeMicroseconds(servo);
myservo.writeMicroseconds(1400);
/*if(readString.indexOf("") > -1){
digitalWrite(Pin3, LOW);
Serial.println("LED off");
Pin3ON = false;
//--------------------------HTML------------------------
client.println("Content-Type: text/html");
client.println();
client.print("<html><head>");
client.print("<title>Servotest</title>");
client.println("</head>");
client.print("<body bgcolor='#444444'>");
client.println("
<hr />");
client.println("<h1><div align='center'><font color='#2076CD'>Servotest</font color></div></h1>");
client.println("<hr />
client.println("<tr bgColor='#222222'>");
client.println("<td bgcolor='#222222'><font face='Verdana' color='#CFCFCF' size='2'>Servo Test
</font></td>");
client.println("<td align='center' bgcolor='#222222'><form method=get><input type='text' name='servo'><input type='submit' value='Drehen'></form></td>");
client.println("<td align='center' bgcolor='#222222'><form method=get><input type=submit name='servo' value='90'></form></td>");
client.println("<td align='center'><font color='green' size='5'>Servovalue: ");
client.print(servo);
client.println("</tr>");
client.println("</table>");
client.println("</body></html>");
readString="";
client.stop();
This is creating a String object bu converting the value 100 to a string, and then wrapping that string in the String object. It then copies that String to readString, wasting more memory. What did you think it was doing?
Well, now you know.
do {
if(readString>0)
while(x<4);
A for loop is so much easier to understand…
If you printed out Data after filling it, you’d see that it contained ‘=’, ‘x’, ‘x’, and ‘x’. Which, by the way, is not the same as “=xxx”.
servo = atof(Data);
The atof() function (Why are you converting what you expect to be an int to a float?) expects a NULL terminated array of characters. You are not passing it a NULL terminated array of characters.
Like maybe String::indexOf()?
Because readString doesn't contain an = sign? I don't know. I can't see that you are printing readString, or what you are doing to cause readString to be valued. You've got to help out a little...
And to preempt the next problem - As you are running a shield and a servo, you should consider separate power as this will likely cause you problems soon if not already.
See the links in my signature for a demonstration why
Ah, ok sry I mean this part:
it looks like I dont get any chars in readString but I dont know where i did the mistake…
void loop(){
if (client)
if (readString.length() < 100) readString = readString + c; //read chars one by one and store them in readString
if (c == '\n') //...till the end of line
Serial.println(readString); //I forgot this in my previous post
ind1 = readString.indexOf("=");
ServoString = readString.substring(ind1, ind1+4); //I wonder if thats going to work :-P
Serial.println(ServoString);
This implies that you have a maximum length command in mind. In which case, you should ditch the String class, and use a static char array. If you persist in this folly (and you might be able to), at least minimize the amount of thrashing that goes on by using the += operator.
readString += c;
Snippets don’t tell us anything.
But, before you paste any more code, use the Tools + Auto Format option. That random indenting is quite unprofessional.
