Ethernet shield stop responding after some hours
My Ethernet shield stop responding after some hours and needs restart with the restart button
is this hardware related?
Second question is PWM pin (4) occupied by the SD card , i dont use SD card , but i need the Pin 4 for some other purposes.
void StartWeb()
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
       if (client.available()) {
         char c = client.read();
          // serch parameter from "HTTP GET"
          if(gflag){
            if(c != ' '){
                parm += c;
            }else{
                gflag = false;
          if(c == '?' && parm == ""){
            gflag = true;
   if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
         if(parm == ""){ // normal HTTP access
                client.println(F("HTTP/1.1 200 OK"));
                client.println(F("Content-Type: text/html"));
                client.println(F(""));
	 	client.println(F("<html><head></head><body>HELLO!</body></html> "));
              else{ // using XMLhttpObject access
                      //IF SUBMIT FROM TIME
                        client.println(F("Content-Type: text/html"));client.println(F(""));
                       int check = parm.indexOf('=');
                          if(check != -1){
				//TIME
				if (hrs < 10) client.print(F("0"));client.print( hrs );client.print(":");if (mins < 10) client.print(F("0"));client.print(mins);client.print(F(":"));if (secs < 10) client.print(F("0"));
				client.print(secs);client.print(F(" "));if (date < 10) client.print(F("0"));client.print(date);client.print(F("-"));if (month < 10) client.print("0");client.print(month);client.print(F("-"));if (year < 10)client.print(F("0"));client.println(year);
            parm = "";
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
what i mean stop responding , is that , i cant even ping to it , the mega is running fine, it connected in a hub , and the hub to my rooter
Have you tried any other server code as a test? Here is mine in the playground.
http://playground.arduino.cc/Code/WebServerST
edit: If the ethernet port LEDs are still on, then this is an indication there are no available sockets:
If you don't insert a card into the slot you can use pin 4 for any purpose you like.
SurferTim:
Arduino Playground - HomePage
all the Ethernet leds
COLL
FULLD
100M
LINK
PWR
are ON only the TX and RX are not.. Probably there are no available sockets., but how do i handle this , is there any example?
Yes. Did you try my code in the link I posted above? It should close the sockets correctly.
i added this part
loopCount++;
      // if 10000ms has passed since last packet
      if(loopCount > 10000) {
        // close connection
        client.stop();
        Serial.println("\r\nTimeout");
and so far after 2 days , and "abuse" stress test , the controller respond without problems..! thanks!
Thanks for that info. That timeout code is the latest change I made just a few days ago.
