Hi there,
I'm testing the dnswebclient example that come with Arduino IDE.
Version 23
Ethernet Shield - Sparkfun, just received it.
Arduino Uno
Using the example dnswebclient sketch, I'm trying to connect to a upc site and retrieve product information using the barcode. In this case it is a rice mix.
I receive a "404 not Found " error.
Works fine if I use the string in a browser, returns the info.
I have not be able to find any topics on this and wondering if anyone has seen this issue?
The code and return data is included below. I did not change the example except for the URL.
Tested with the google example and it worked fine.
Thanks
Randy
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
API Key - c4f9ccc27f967b1cc0ba3c5fde92f3a8
www.upcdatabase.org/api/xml/c4f9ccc27f967b1cc0ba3c5fde92f3a8/UPCGoesHere
OUTPUT if Exists
<?xml version="1.0" encoding="ISO-8859-1"?>
<output xmlns="http://www.upcdatabase.org/">
<valid>true</valid>
<number>0111222333444</number>
<itemname>UPC Database Testing Code</itemname>
<description>http://www.upcdatabase.org/code/0111222333444</description>
<price>123.45</price>
<ratingsup>2</ratingsup>
<ratingsdown>0</ratingsdown>
</output>
OUTPUT if ERROR
<valid>false</valid>
<error>301</error>
<reason>Code does not exist!</reason>
</output>
Error codes:
101 - API Key length is incorrect
105 - API Key incorrect
201 - You did not enter a code
205 - The code you entered was non-numeric
301 - Code does not exist
created 18 Dec 2009
by David A. Mellis
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(174,122,37,98); // www.upcdatabase.org
String Testupc = "071429097056";
char serverName[] = "www.upcdatabase.org";
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// start the serial library:
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(serverName, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /api/xml/c4f9ccc27f967b1cc0ba3c5fde92f3a8/071429097056 HTTP/1.0"); //HTTP/1.0
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for(;;)
Message returns
connected
HTTP/1.1 404 Not Found
Date: Sat, 17 Dec 2011 03:08:03 GMT
Server: Apache/2.2.21 (Unix) mod_ssl/2.2.21 OpenSSL/0.9.8e-fips-rhel5 mod_fcgid/2.3.6 Phusion_Passenger/3.0.9 mod_bwlimited/1.4
Accept-Ranges: bytes
Connection: close
Content-Type: text/html
X-Pad: avoid browser bug
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html>
<head>
<title>404 Not Found</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<style type="text/css">
body {
font-family: Verdana, Arial, Helvetica, sans-serif;
font-size: 12px;
background-color:#367E8E;
scrollbar-base-color: #005B70;
scrollbar-arrow-color: #F3960B;
scrollbar-DarkShadow-Color: #000000;
color: #FFFFFF;
margin:0;
a { color:#021f25; text-decoration:none}
h1 {
font-size: 18px;
color: #FB9802;
padding-bottom: 10px;
background-image: url(sys_cpanel/images/bottombody.jpg);
background-repeat: repeat-x;
padding:5px 0 10px 15px;
margin:0;
#body-content p {
padding-left: 25px;
padding-right: 25px;
line-height: 18px;
padding-top: 5px;
padding-bottom: 5px;
h2 {
font-size: 14px;
font-weight: bold;
color: #FF9900;
padding-left: 15px;
</style>
</head>
<body>
<div id="body-content">
<!-- start content-->
instead of REQUEST_URI, we could show absolute URL via:
http://HTTP_HOST/REQUEST_URI
but what if its https:// or other protocol?
SERVER_PORT_SECURE doesn't seem to be used
SERVER_PORT logic would break if they use alternate ports
<h1>404 Not Found</h1>
<p>The server can not find the requested page:</p>
<blockquote>
(none)/api/xml/c4f9ccc27f967b1cc0ba3c5fde92f3a8/071429097056 (port 80)
</blockquote>
<p>
Please forward this error screen to zemni.site5.com's
<a href="mailto:system-notifications@monitor.accountsupportgroup.com?subject=Error message [404] 404 Not Found for (none)/api/xml/c4f9ccc27f967b1cc0ba3c5fde92f3a8/071429097056 port 80 on Friday, 16-Dec-2011 21:08:03 CST">
WebMaster</a>.
</p>
<hr />
<address>Apache/2.2.21 (Unix) mod_ssl/2.2.21 OpenSSL/0.9.8e-fips-rhel5 mod_fcgid/2.3.6 Phusion_Passenger/3.0.9 mod_bwlimited/1.4 Server at zemni.site5.com Port 80</address>
<!-- end content -->
</div>
</body>
</html>
disconnecting.
