Ethernet shield Twitter Error
Hi everyone I'm trying to use the ethernet shield to post a tweet But the problem is it keeps showing "connecting failed" I'm not that expert in programming.. so could anyone plz Help me, Cause I have to hand in my project as soon as possible And twitter consider to be the most important thing in my project
More info.: it complies fine with no error and I'm using arduino uno The program of the twitter I got it from simple post example and I already have my Token
You may not be using the correct ip for the twitter connection. Since you didn’t post your code or a link to the example, it is impossible to tell.
But that will not be your only problem. Unless you are using a relay server to translate your tweet to SSL, it won’t work. Twitter is now using port 443 (SSL) only to post tweets.
