i tried the Webclient example with the Ethernet Shield v2 and sometimes I get readable data but most of the time not:
connecting...
connected
Y©FIªx?ä«Å(û ü_eFv8t?î´!S?ùùòÃ6éK??c
disconnecting.
connecting...
connected
[ìe.timers={};window.google.startTick=function(a,b){i[a]={t:{start:(new Date).getTime()},bfr:!(!b)}};window.google.tick=function(a,b,c){if(!i[a])google.startTick(a);i[a].t[b]=c||(new Date).getTime()};google.sta{}};
window.google.sn="webhp";var i=window.google.timers={};window.google.startTick=function(a,b){i[a]={t:{start:(new Date).getTime()},bfr:!(!b)}};window.google.tick=function(a,b,c){if(!i[a])google.startTick(a);i[a].t[b]=c||(new Date).getTime()};google.sta{}};
disconnecting.
connecting...
connected
È×,|øXW ¦?ÂÉéHQü?q×fæ¡ùÍíe\@Ð öË?ß
FP¢
disconnecting.
connecting...
connected
[¨a
</PRE>
zu verarbeiten, trat der folgende F
disconnecting.
connecting...
connected
STRONG>Ungültige Anfrage</STRONG>
</UL>
disconnecting.
Here’s the code:
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192,168,2,177 };
byte server[] = { 74,125,39,147 }; // Google
byte gateway[] = { 192,168,2, 1 };
byte subnet[] = { 255, 255, 255, 0 };
Client client(server, 80);
// start the Ethernet connection:
Ethernet.begin(mac, ip, gateway, subnet);
// start the serial library:
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect()) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET / HTTP/1.0");
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for(;;)
Could someone try the code and tell me if the results are the same?
