Ethernet Shield with index.htm SDcard.
zoom thanks for reply, and your attention.
But i dont understand how can transform this code to be working whith my index.html
see.. my index.html code:
now, i want when click on w3schools.jpg...that turn led on pin3
and when click again turn led on pin3.
this is code i want tranform:
#include <LiquidCrystal.h>
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
#define BUFSIZ 128
#define greenLEDandBEEP 2
#define redLEDpin 3
boolean led2 = true;
int hits = 0; // Set the number of hits the hit counter will start at.
int units = 0;
int count = 0;
int photocellPin = 2;
int photocellReading;
LiquidCrystal lcd(4, 5, 6, 7, 8, 9);
//Local ethernet setup
byte mac[] = {
0x90, 0xA2, 0xDA, 0x00, 0x1C, 0x0E };
byte ip[] = {
192, 168, 1, 80 };
char rootFileName[] = "index.htm";
Server server(8080);
//SD card stuff
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode()) {
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
lcd.begin(16, 2);
lcd.print("Web Server v2.00");
lcd.setCursor(0, 1);
lcd.print("Hits:");
pinMode(greenLEDandBEEP, OUTPUT);
pinMode(redLEDpin, OUTPUT);
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
if (!volume.init(&card)) error("vol.init failed!");
PgmPrint("Volume is FAT");
Serial.println(volume.fatType(),DEC);
Serial.println();
if (!root.openRoot(&volume)) error("openRoot failed");
PgmPrintln("Files found in root:");
root.ls(LS_DATE | LS_SIZE);
Serial.println();
PgmPrintln("Files found in all dirs:");
root.ls(LS_R);
Serial.println();
PgmPrintln("Done");
Ethernet.begin(mac, ip);
server.begin();
if(count >=500)
led2 = !led2;
digitalWrite(redLEDpin, led2);
count = 0;
count +=1;
char clientline[BUFSIZ];
char *filename;
int image = 0;
int index = 0;
Client client = server.available();
if (client) {
boolean current_line_is_blank = true;
index = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
if (index >= BUFSIZ)
index = BUFSIZ -1;
continue;
clientline[index] = 0;
filename = 0;
Serial.println(clientline);
if (strstr(clientline, "GET / ") != 0) {
filename = rootFileName;
if (strstr(clientline, "GET /") != 0) {
if (!filename) filename = clientline + 5;
(strstr(clientline, " HTTP"))[0] = 0;
Serial.println(filename);
if (! file.open(&root, filename, O_READ)) {
client.println("HTTP/1.1 404 Not Found");
client.println();
client.println("
Error 404
client.println("The file does not exist.");
client.println("");
break;
Serial.println("Opened!");
//File types
if (strstr(filename, ".htm") != 0)
else if (strstr(filename, ".css") != 0)
client.println("Content-Type: text/css");
else if (strstr(filename, ".png") != 0)
client.println("Content-Type: image/png");
else if (strstr(filename, ".jpg") != 0)
client.println("Content-Type: image/jpeg");
else if (strstr(filename, ".gif") != 0)
client.println("Content-Type: image/gif");
else if (strstr(filename, ".3gp") != 0)
client.println("Content-Type: video/mpeg");
else if (strstr(filename, ".pdf") != 0)
client.println("Content-Type: application/pdf");
else if (strstr(filename, ".js") != 0)
client.println("Content-Type: application/x-javascript");
else if (strstr(filename, ".xml") != 0)
client.println("Content-Type: application/xml");
client.println("Content-Type: text");
client.println();
int16_t c;
while ((c = file.read()) >= 0) {
//Serial.print((char)c); //Prints all HTML code to serial (For debuging)
client.print((char)c); //Prints all HTML code for web page
//Hit counter math
if(units >= 2)
hits ++;
units = 0;
units +=1;
//End hit counter math
//Print the hit counters and light value
lcd.setCursor(6, 1);
lcd.print(hits); //Print hits for LCD hit counter
client.print(""); //HTML code starts here
client.print("<P align="center">");
client.print("Hits since reset: ");
client.print(hits); //Print hits to client
client.print("
photocellReading = analogRead(photocellPin);
client.print("Light reading: ");
client.print(photocellReading); //Prints light reading to client
// A few threshholds
if (photocellReading < 10) {
client.print(" - Dark");
else if (photocellReading < 200) {
client.print(" - Dim");
else if (photocellReading < 500) {
client.print(" - Light");
else if (photocellReading < 800) {
client.print(" - Bright");
else {
client.print(" - Very bright");
client.print("
"); //HTML code ends here
//End hit counter and light value
file.close();
else {
client.println();
client.println("
Error 404
client.println("");
break;
digitalWrite(greenLEDandBEEP, HIGH);
delay(1);
digitalWrite(greenLEDandBEEP, LOW);
client.stop();
understand me?
