Hello. Faced with strange problem: When using the following code:
#include <SPI.h>
#include <Ethernet.h>
#include "SIM900.h"
#include <SoftwareSerial.h>
//If not used, is better to exclude the HTTP library,
//for RAM saving.
//If your sketch reboots itself proprably you have finished,
//your memory available.
//#include "inetGSM.h"
//If you want to use the Arduino functions to manage SMS, uncomment the lines below.
#include "sms.h"
SMSGSM sms;
#define SEND_LED 9
#define GET_SMS_LED 8
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20];
String sms_text;
//IPAddress ip(191,11,1,1);
//char server[] = "112.travel";
IPAddress server(194,187,48,247);
int send_sms_status = 2;
EthernetClient client;
pinMode(SEND_LED, OUTPUT);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
Serial.print("My IP address: ");
for (byte thisByte = 0; thisByte < 4; thisByte++) {
Serial.print(Ethernet.localIP()[thisByte], DEC);
Serial.print(".");
Serial.println();
Serial.println("GSM Shield testing.");
//Start configuration of shield with baudrate.
//For http uses is raccomanded to use 4800 or slower.
if (gsm.begin(2400)){
Serial.println("\nstatus=READY");
started=true;
else Serial.println("\nstatus=IDLE");
if(started){
//Enable this two lines if you want to send an SMS.
//if (sms.SendSMS("3471234567", "Arduino SMS"))
//Serial.println("\nSMS sent OK");
// pinMode(SEND_LED, OUTPUT);
// pinMode(GET_SMS_LED, OUTPUT);
//IPAddress ip(Ethernet.localIP());
Serial.println("sdsd");
Serial.println(str_replace("sms text is!!!"));
Serial.println("sdsd1");
// connectToServer(str_replace("sms text is!!!"), "+380501234567");
boolean StartGetResult = false;
boolean start_send_serv = false;
String server_result, ServRes;
long PrevMillForSend = 0;
void loop () {
//func_send_server (str_replace("sms text is!!!"), "+380501234567");
if(started){
//Read if there are messages on SIM card and print them.
if(gsm.readSMS(smsbuffer, 160, n, 20))
Serial.println(n);
Serial.println(smsbuffer);
the port there is no output. If I removed from the loop of inspection of incoming sms:
#include <SPI.h>
#include "SIM900.h"
//for RAM saving.
#include "sms.h"
SMSGSM sms;
#define SEND_LED 9
int numdata;
char n[20];
String sms_text;
while (!Serial) {
for(;;)
Serial.print(".");
Serial.println();
started=true;
if(started){
void loop () {
if(started){
/*if(gsm.readSMS(smsbuffer, 160, n, 20))
Serial.println(n);
all work is fine. Status is GMS = READY and normally displays my IP. Can someone tell me what be the problem? I would greatly appreciate your help!
