Ethernet socket connection unreliable
Hello,
I wrote an arduino software to control each WS2814 led with an python script (pyseril, serial_for_url) via ethernet. The board I use is an Olimex ESP32 POE-Board.
Now, if I send an command to enable an LED it only works sporadically. It looks like some commands are lost, but I have no idea why. This is my first time using the ethernet library but connect to the router and getting an IP from DHCP works fine.
I hope someone can give me advice to my code:
    Software to control WS2815 leds with python via ethernet
// === DEFINITIONS FOR NETWORK COMMUNICATION ===
// Important to be defined BEFORE including ETH.h for ETH.begin() to work.
// Example RMII LAN8720 (Olimex, etc.)
#ifndef ETH_PHY_TYPE
#define ETH_PHY_TYPE    ETH_PHY_LAN8720
#define ETH_PHY_ADDR    0
#define ETH_PHY_MDC     23
#define ETH_PHY_MDIO    18
#define ETH_PHY_POWER   -1
#define ETH_CLK_MODE    ETH_CLOCK_GPIO0_IN
#endif
// Include network library
#include <ETH.h>
// Ethernet server definitions
#define ETH_SERVER_PORT       8123
#define DATA_LEN_MAX          3
#define CMD_LED_OFF           1
#define CMD_SET_LED_COLOR     2
// === DEFINITIONS FOR LED CONTROL ===
// LED data pin
#define PIN                   2
#define PIXEL_COUNT           20
// === VARIABLES FOR NETWORK COMMUNICATION ===
// Global variable which indicates if network is connected
static bool eth_connected = false;
// Initialize the Ethernet server library
NetworkServer server(ETH_SERVER_PORT);
// Typedef for data structure
typedef struct {
  unsigned char cmd;
  unsigned char data_length;
  unsigned char data_buffer[DATA_LEN_MAX];
} CMD_t;
CMD_t rx_data;
// === VARIABLES FOR LED CONTROL ===
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIN, NEO_GRB + NEO_KHZ800);
// WARNING: onEvent is called from a separate FreeRTOS task (thread)!
// Handles ethernet state machine
void onEvent(arduino_event_id_t event) {
  switch (event) {
    case ARDUINO_EVENT_ETH_START:
      Serial.println("ETH Started");
      // The hostname must be set after the interface is started, but needs
      // to be set before DHCP, so set it from the event handler thread.
      ETH.setHostname("esp32-ethernet");
    case ARDUINO_EVENT_ETH_CONNECTED: Serial.println("ETH Connected"); break;
    case ARDUINO_EVENT_ETH_GOT_IP:
      Serial.println("ETH Got IP");
      Serial.println(ETH);
      eth_connected = true;
    case ARDUINO_EVENT_ETH_LOST_IP:
      Serial.println("ETH Lost IP");
    case ARDUINO_EVENT_ETH_DISCONNECTED:
      Serial.println("ETH Disconnected");
    case ARDUINO_EVENT_ETH_STOP:
      Serial.println("ETH Stopped");
    default: break;
// Calculates modbus crc16
uint16_t crc16_modbus(uint8_t *data, uint16_t length) {
  uint16_t crc = 0xFFFF;
  uint16_t i, j;
  for (i = 0; i < length; i++)
    crc ^= (uint16_t)data[i]; // XOR byte into least sig. byte of crc
    for (j = 0; j < 8; j++) // Loop over each bit
      if (crc & 0x0001) // If the LSB is set
        crc >>= 1; // Shift right and XOR 0xA001
        crc ^= 0xA001;
      else // Else LSB is not set
        crc >>= 1; // Just shift right
  return crc;
// Receive and save data from client
bool recv_data(NetworkClient* client) {
  // Check if data is available
  if (client->available() >= 4) {
    Serial.println("Received data");
    // Read first two bytes
    rx_data.cmd = client->read();
    rx_data.data_length = client->read();
    // Check remaining data
    if (rx_data.data_length + 2 >= client->available()) {
      // Read remaining data
      client->readBytes(rx_data.data_buffer, rx_data.data_length);
    else {
      client->flush();
      return false;
    // Combine the received CRC bytes
    uint16_t crc = client->read() + (client->read() << 8);
    // Calculate CRC
    uint16_t crc_check = crc16_modbus((uint8_t*) &rx_data, 2 + rx_data.data_length);
    // Flush remaining data
    client->flush();
    if (crc == crc_check) {
      Serial.println("CRC OK");
      return true;
    else {
      Serial.println("CRC NOK");
      return false;
    return (crc == crc_check);
  return false;
// Parse data received from client
void parse_data(NetworkClient* client) {
  uint32_t color;
  switch(rx_data.cmd) {
    case CMD_LED_OFF:
      Serial.println("LED OFF");
      // Check if data length is valid
      if (rx_data.data_length != 1) {
      // Check of all leds should be turned off
      if (rx_data.data_buffer[0] == 0xFF) {
        // Turn all leds off
        strip.clear();
      // Turn specific led off
      strip.setPixelColor(uint16_t(rx_data.data_buffer[0]), strip.Color(0, 0, 0));
    case CMD_SET_LED_COLOR:
      Serial.println("SET LED COLOR");
      if (rx_data.data_length != 4) {
      // Get color from data
      color = strip.Color(uint8_t(rx_data.data_buffer[1]), uint8_t(rx_data.data_buffer[2]), uint8_t(rx_data.data_buffer[3]));
      // Check of all leds should be turned on
        // Turn all leds on
        for (uint16_t i = 0; i < strip.numPixels(); i++) {
          strip.setPixelColor(i, color);
        strip.show();
      Serial.print("Setting led with id:");
      Serial.println(rx_data.data_buffer[0]);
      Serial.print("Color:");
      Serial.println(rx_data.data_buffer[1]);
      Serial.println(rx_data.data_buffer[2]);
      Serial.println(rx_data.data_buffer[3]);
      // Turn specific led on
      strip.setPixelColor(uint16_t(rx_data.data_buffer[0]), color);
      strip.show();
    default:
  // Initialize serial logging
  // Initialize led strip
  strip.begin();
  strip.setBrightness(100);
  strip.setPixelColor(0x01, strip.Color(255, 0, 0));
  strip.show();
  // Pass connection event handler to network library
  Network.onEvent(onEvent);
  // Start network handling
  ETH.begin();
  // Start server
  server.begin();
  // if an incoming client connects, there will be bytes available to read:
  NetworkClient client = server.available();
  if (client) {
    // Check if data was received
    if(recv_data(&client)) {
      Serial.println("Parsing data...");
      // Parse data
      parse_data(&client);
The python script to controll the leds:
#!/usr/bin/python
# -*- coding: utf-8 -*-
# @file servo.py
# @brief Provides functions talk to arduino servo controller.
# @section author_main Author(s)
# - Created by Fabian Plaimauer.
# - Modified by ???.
"""! @brief Provides functions talk to arduino servo controller."""
import logging
import threading
import serial
CMD_LED_OFF                     = 0x01
CMD_LED_OFF_DATA_LENGTH         = 0x01
CMD_SET_LED_COLOR               = 0x02
CMD_SET_LED_COLOR_DATA_LENGTH   = 0x04
class LEDController:
    """! LED controller class handles controlling the ws2815 led strip via sockets."""
    def __new__(cls, configuration: dict):
        """! Singleton constructor."""
        if not hasattr(cls, 'instance'):
            cls.instance = super(LEDController, cls).__new__(cls)
        return cls.instance
    def __init__(self, configuration: dict) -> None:
        """! Initializes led settings.
		@param led_config dictionary with config parameters
        logging.debug("called")
        # Save parameters
        self._config = configuration
        self._url = f'socket://{self._config["ip"]}:{self._config["port"]}'
        # Get mutex lock
        self._lock = threading.Lock()
        # Create empty serial handler
        self._serial_handler = None
    def connect(self) -> bool:
        """! Connect to arduino com port."""
        # Try opening serial port (thread-safe)
        try:
            # Lock this code section
            with self._lock:
                # Check if handler already exists
                if not self._serial_handler:
                    self._serial_handler = serial.serial_for_url(
                        url = self._url,
                        timeout = self._config["timeout"],
                        write_timeout = self._config["write_timeout"]
        except Exception as e:
            logging.critical(e)
            return False
        return True
    def check_connection(self) -> bool:
        """! Check if connected to arduino com port."""
        with self._lock:
            return self._serial_handler.is_open if self._serial_handler else False
    def disable(self, id = 0xFF):
        """! Disabled provided led, if no paramter is provided, will be disabled."""
    def set_color(self, id = 0xFF, green = 0x00, red = 0x00, blue = 0x00) -> bool:
        """! Sets color for provided led."""
        # Create data packet
        packet = bytearray()
        packet.append(CMD_SET_LED_COLOR)
        packet.append(CMD_SET_LED_COLOR_DATA_LENGTH)
        packet.append(id)
        packet.append(green)
        packet.append(red)
        packet.append(blue)
        # Calculate CRC
        packet.extend(self._modbus_crc16(packet).to_bytes(2, 'little'))
        return self._send_recv_data(packet, 0)
    ##### HELPER FUNCTIONS #####
    # Helper function to send servo data and check response
    def _send_recv_data(self, packet: bytearray, reply_length: int) -> bool | bytearray:
        """! Helper function to send data and check response."""
        try:
            # Get mutex
            with self._lock:
                # Reset buffers
                self._serial_handler.reset_input_buffer()
                self._serial_handler.reset_output_buffer()
                # Send packet
                logging.error("write: %s", " ".join(f"0x{b:02X}" for b in packet))
                self._serial_handler.write(packet)
                if reply_length == 0:
                    return True
                # Read data and wait until timeout
                reply = self._serial_handler.read(reply_length)
                logging.debug("received: %s", " ".join(f"0x{b:02X}" for b in reply))
                # Check if timeout occured
                if len(reply) == reply_length:
                    return reply
                logging.debug("invalid reply length")
            logging.error(e)
        # Out of tries without success
        logging.debug("failed sending data")
        return False
    # Helper function to calculate modbus crc16
    def _modbus_crc16(self, data: bytes) -> int:
        """! Calculate the Modbus CRC16."""
        crc = 0xFFFF
        for _, byte in enumerate(data):
            crc ^= byte
            for _ in range(8):
                if crc & 1:
                    crc >>= 1
                    crc ^= 0xA001
                else:
                    crc >>= 1
        return crc
config = {
    "ip": "192.168.88.244",
    "port": 8123,
    "timeout": 3,
    "write_timeout": 3,
import time
led = LEDController(config)
if led.connect():
    led.set_color(0x03, 0xFF, 0xFF)
    for i in range(1, 10):
        led.set_color(i, 0x00, 0xFF)
        time.sleep(1)
else:
    print(led.check_connection())
    print("FAiled to connect")
Can you establish at which stage the commands are lost ?
  • Are the commands actually sent ?
  • Are the commands received ?
  • Are the commands in the expected format ?
  • Do the commands contain valid data ?
  • Are the commands acted upon correctly ?
Good evening UKHeliBob,
I think I already answered most of it.
    Yes
    Sporadically, basically 1 out of 5 but I have no idea why.
    Yes, when the data is received
    Yes, when the data is received then the CRC check is also ok
    LG
How do we know the answers to the questions are valid. Valid generally means showing us the serial output with the results of Serial.println("Something happened");
Check duplex, both ends must use the same, half or full. Less likely; check how much power is needed and see if the PSE (power source) can provide.
Power source is definitely enough since I can drive all leds in a loop. The cablen is also full duplex.
Duplex has nothing to do with the cable.
There exist old half duplex cables, but what exactly did you mean?
Did you mean the connection state? This is what the switch says:
I now did some testing and found out that only the write from python is received by the board. All others throw connection errors:
python.exe c:/Users/User/Desktop/ws2814_test.py
Set color: 20
ERROR:root:write: 0x02 0x04 0x14 0x00 0xFF 0x00 0xB4 0x39
Set color: 21
ERROR:root:write: 0x02 0x04 0x15 0x00 0xFF 0x00 0xB5 0xC5
ERROR:root:write failed: [WinError 10053] An established connection was aborted by the software in your host machine
Set color: 22
ERROR:root:read failed: [WinError 10053] An established connection was aborted by the software in your host machine
Set color: 23
If A use half duplex and B full duplex, there will be disruptions to the communication. Still got nothing to do with the cable.
It's rare these days that anything else than Full duplex is utilized, so probably not the case here. (But just because the switch reports FD, doesn't mean the other end uses it)
Anyway, seems you got hold of some software related issue there.
Yeah, I'm pretty sure its software related.
Via serial I found out the connection settings the board uses:
*eth0: <UP,100M,FULL_DUPLEX,AUTO,ADDR:0x0> (DHCPC,GARP,IP_MOD)
      ether A0:B7:65:CB:B4:BB
      inet 192.168.1.94 netmask 255.255.255.0 broadcast 192.168.1.255
      gateway 192.168.1.1 dns 192.168.1.1
