I've used Ethernet for doing telnet, UDP, and now web server, all with excellent results. But I now have an application for which it would be nice to be able to have both web server and UDP access simultaenously. Is this even possible, given that the EthernetServer object is created for a specific port number?
Regards,
Ray L.
Peter_n
December 29, 2014, 6:17pm
2
Yes, it is possible.
I have a single object/class definition for webserver, and a single function that serves the webpage(s) to handle that.
I declared just one webclient, but I use that object for different tasks. To read websites, to upload to ThingSpeak.com , and so on.
I also have a UDP, and use it now and then to get the time. I might use that same udp object for other things, but not yet.
And I can retrieve mail from a mail server and send mail to a mailserver.
Peter_n:
related question and not trying to hijack this thread, but @Peter_n , would you have posted an example? I am looking to get Unread mail count for a project I have been working on.
Peter_n:
Peter,
That is good news! So, if I understand correctly (a major assumption in this case.......), in the simplest case, the code would look something like this?
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10, 0, 0, 42);
EthernetServer udpserver(6666);
WebServer webserver(80);
Ethernet.begin(mac, ip);
udpserver.begin();
webserver.begin();
void loop(void)
EthernetClient udpclient = udpserver.available();
if (udpclient) {
// Handle udp traffic
EthernetClient webclient = webserver.available();
if (webclient) {
// Handle web traffic
Regards,
Ray L.
zoomkat
December 29, 2014, 7:36pm
5
Below is an example of dual server code from past forum postings.
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// change to your network settings
IPAddress ip( 192,168,2,2 );
IPAddress gateway( 192,168,2,1 );
IPAddress subnet( 255,255,255,0 );
EthernetServer server(80);
EthernetServer server2(8080);
// disable w5100 while setting up SD
pinMode(10,OUTPUT);
digitalWrite(10,HIGH);
Serial.print(F("Starting SD.."));
if(!SD.begin(4)) Serial.println(F("failed"));
else Serial.println(F("ok"));
Ethernet.begin(mac, ip, gateway, gateway, subnet);
delay(2000);
server.begin();
server2.begin();
Serial.println(F("Ready"));
if(client) {
boolean currentLineIsBlank = true;
boolean currentLineIsGet = true;
int tCount = 0;
char tBuf[64];
int r,t;
char *pch;
IPAddress ipBuf;
Serial.print(F("Client request: "));
while (client.connected()) {
while(client.available()) {
char c = client.read();
if(currentLineIsGet && tCount < 63)
tBuf[tCount] = c;
tCount++;
tBuf[tCount] = 0;
if (c == '\n' && currentLineIsBlank) {
// send a standard http response
Serial.println(tBuf);
Serial.print(F("POST data: "));
while(client.available()) Serial.write(client.read());
pch = strtok(tBuf,"?");
while(pch != NULL)
if(strncmp(pch,"t=",2) == 0)
t = atoi(pch+2);
Serial.print(F("t="));
Serial.println(t,DEC);
if(strncmp(pch,"r=",2) == 0)
r = atoi(pch+2);
Serial.print(F("r="));
Serial.println(r,DEC);
pch = strtok(NULL,"& ");
Serial.println(F("Sending response"));
client.println(F("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<html>"));
client.println(F("<body><H1>TEST</H1>"));
client.println(F("<form method=GET>T: <input type=text name=t>
client.println(F("R: <input type=text name=r>
<input type=submit></form>"));
client.println(F("</body></html>\r\n"));
client.stop();
else if (c == '\n') {
currentLineIsGet = false;
else if (c != '\r') {
currentLineIsBlank = false;
Serial.println(F("done"));
client = server2.available();
if(client) {
Serial.println(F("Server2"));
int tCount = 0;
char tBuf[64];
int r,t;
char *pch;
IPAddress ipBuf;
tBuf[tCount] = c;
tCount++;
tBuf[tCount] = 0;
client.println(F("<body><H1>TEST Server 2</H1>"));
client.stop();
Peter_n
December 29, 2014, 8:38pm
7
BulldogLowell, this is code for some specific use, but it should not be hard to change it : Arduino Playground - EmailPOP3
The client object that I use for email is actually the same client that I also use for other things.
