Danke schonmal,
aber c ist in dem Falle aber nicht immer eine Zahl, sondern auch folgendes:
char c = client.read();
if(c == '*'){
printHtmlHeader(client); //call for html header and css
printLoginTitle(client);
printHtmlFooter(client);
//sentHeader = true;
break;
if(!sentHeader){
printHtmlButtonTitle(client); //print the button title
//This is for the arduino to construct the page on the fly.
sentHeader = true;
//read user input
// char c = client.read();
//if there was reading but is blank there was no reading
if(reading && c == ' '){
reading = false;
//if there is a ? there was user input
if(c == '?') {
reading = true; //found the ?, begin reading the info
// if there was user input switch the relevant output
if(reading){
//if user input is H set output to 1
if(c == 'H') {
outp = 1;
//if user input is L set output to 0
if(c == 'L') {
outp = 0;
Serial.print(c); //print the value of c to serial communication
//Serial.print(outp);
//Serial.print('\n');
switch (c) {
case '0':
//add code here to trigger on 0
triggerPin(outputAddress[0], client, outp);
break;
case '1':
//add code here to trigger on 1
triggerPin(outputAddress[1], client, outp);
break;
case '2':
//add code here to trigger on 2
triggerPin(outputAddress[2], client, outp);
break;
case '3':
//add code here to trigger on 3
triggerPin(outputAddress[3], client, outp);
break;
case '4':
//add code here to trigger on 4
triggerPin(outputAddress[4], client, outp);
break;
case '5':
//add code here to trigger on 5
triggerPin(outputAddress[5], client, outp);
//printHtml(client);
break;
case '6':
//add code here to trigger on 6
triggerPin(outputAddress[6], client, outp);
break;
case '7':
//add code here to trigger on 7
triggerPin(outputAddress[7], client, outp);
break;
case '8':
//add code here to trigger on 8
triggerPin(outputAddress[8], client, outp);
break;
case '9':
//add code here to trigger on 9
triggerPin(outputAddress[9], client, outp);
break;
} //end of switch case
}//end of switch switch the relevant output
//if user input was blank
if (c == '\n' && currentLineIsBlank){
printLastCommandOnce = true;
printButtonMenuOnce = true;
triggerPin(777, client, outp); //Call to read input and print menu. 777 is used not to update any outputs
break;
