Ethernet to Internet ??? Addressing problem.
I get a Arduino Ethernet Shield on my Arduino Uno board.
Make a sketch that initialize my Ethernet with the folowing code :
#include <Ethernet.h>
#include <SPI.h>
byte ip[] = { 192, 168, 0, 198 }; //Manual setup only
byte gateway[] = { 173, 242, 209, 65 }; //Manual setup only
byte subnet[] = { 255, 255, 255, 224 }; //Manual setup only
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetServer server = EthernetServer(80); //port 80
Ethernet.begin(mac, ip, gateway, subnet); //for manual setup
server.begin(); /* Ethernet */
and send data with
client.print();
My sketch work weel if I stay within my router. But if I go outside my router (on internet not Ethernet) unable to find the URL.
Propably a question of addressing my router or my Arduino shield.
If someone can help....it will be appreciate.
Thank
Your challenge is due to this:
On this localnet, your gateway is unreachable. Since it works localnet, I presume the ip is correct, but the subnet mask and/or gateway is incorrect.
edit:
// this
// should be this
Ethernet.begin(mac, ip, gateway, gateway, subnet);
Thank for the help...
I take the subnet mask and the default gateway number on my DLINK device info page on the WAN section.
This is how my code look:
Ethernet.begin(mac, ip, gateway, gateway, subnet); //for manual setup
server.begin();
Which URL address I have to call on my browser to access my arduino outside my localnet ?
Thank again...very appreciate
Alain
Trying different thing......pffffff
Now getting the information by IPCONFIG command in <accessory/dos command>
This is how my code look now:
byte gateway[] = { 192, 168, 0, 1 };
byte subnet[] = { 255, 255, 255, 0 };
server.begin();
But still don't know which URL address I have to call on my browser to access my arduino outside my localnet ?
Alain
Router port forwarding and a dynamic IP service are probably what you need.
https://www.google.com/search?num=100&lr=&hl=en&as_qdr=all&q=router+port+forward+site:http://arduino.cc/forum/&spell=1&sa=X&ei=TjRrUZvMAsXE4AOqw4HgDQ&ved=0CC8QvwUoAA&biw=1134&bih=618
You're right Zoomcat !!! and you too SurferTim the right code was "Ethernet.begin(mac, ip, gateway, gateway, subnet);"
Found the information by reading your old message on this forum before you get back to me Zoomcat...héhéhé
But THANK A LOT for the present message and the old one ....hahahaaha.
I do a port fowarding on my router and it's WORK now. Testing on my cellular.
I think it will work until I shut off my router.... after that my Internet provider will probably assign me a new IP address and i will have to make a new port forwarding or get a dynamic IP service.
Am I obligate to my Internet provider to have a dynamic IP address or it exist differents ways ?
Again thank all for the help....
Alain
u need a Dynamic DNS service
http://dnslookup.me/dynamic-dns/
