Ethernet to iOS problems
This code should be sending data to the iphone app Arduino Manager but will not compile, suggestions?
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
#include <Servo.h>
#include <IOSController.h>
#include <avr/wdt.h>
int Trigger = 600; // value photocell reading must be below to trigger "break"
int CumulativeTotal = -3; //initial value of CumulativeTotal = -3 to account for first "test read" on all sensors
const int LEDpinlowred = 9;//Red LED 1
const int LEDpinmidred = 11; //Red LED 2
const int LEDpintopred = 12;//Red LED 3
const int LEDpinStat = 13;
const int laserPin = 5; //Variable power transmitter
 * Ethernet Library configuration
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x00, 0xC5, 0x79 };  // MAC Address assigned to the board
 * IP info
 * Using DHCP these parameters are not needed
IPAddress ip(192,168,1,220);
IPAddress gateway(192,168,1,220);
IPAddress subnet(255,255,255,0);
 * Initialize the Ethernet server library
EthernetServer server(80);   // Messages received on port 80
#define CHIPSELECT 4;
 * Prototypes of IOSController’s callbacks
void doWork();
void doSync(char *variable);
void processIncomingMessages(char *variable, char *value);
void processOutgoingMessages();
void deviceConnected();
void deviceDisconnected();
 * IOSController Library initialization
begin.IOSController
  pinMode(10, OUTPUT);     // change this to 53 on a mega
  digitalWrite(10, HIGH);  // but turn off the W5100 chip!
  Ethernet.begin(mac, ip, subnet, gateway);
  server.begin();
  pinMode(A0, INPUT); //Low Photocell
  pinMode(A1, INPUT); //Middle Photocell
  pinMode(A2, INPUT); //High Photocell
  pinMode(2, OUTPUT); //Seven Segment Display 'a'
  pinMode(3, OUTPUT); //Seven Segment Display 'b'
  pinMode(4, OUTPUT); //Seven Segment Display 'c'
  pinMode(5, OUTPUT); //Seven Segment Display 'd'
  pinMode(6, OUTPUT); //Seven Segment Display 'e'
  pinMode(7, OUTPUT); //Seven Segment Display 'f'
  pinMode(8, OUTPUT); //Seven Segment Display 'g'                                                ------------------
  pinMode(9, OUTPUT); //Seven Segment Display 'h'                                               |   /0/1/2/    3    |
  pinMode(LEDpinlowred, OUTPUT); //User interface panel LED 0(Red)  diagonostics A2             |                   }
  pinMode(LEDpinmidred, OUTPUT); //User interface panel LED 1(Red)  diagonostics A1             |                 4 |
  pinMode(LEDpintopred, OUTPUT); //User interface panel LED 2(Red)  diognostics A0                ------------------
  pinMode(LEDpinStat, OUTPUT); //User interface panel LED 3(amber) systems status indicator(blink = uploading serial data)(solid = problem)
  pinMode(laserPin, OUTPUT); //Powers laser transmission pole
  digitalWrite (LEDpinlowred, 0);
  delay(350);
  digitalWrite (LEDpinlowred, 1);
  delay(350);
  digitalWrite (LEDpinmidred, 0);
  delay(350);
  digitalWrite (LEDpinmidred, 1);
  delay(350);
  digitalWrite (LEDpintopred, 0);
  delay(350);
  digitalWrite (LEDpintopred, 1);
  delay(750);
  delay(350);
  delay(150);
  delay(150);
  delay(150);
  delay(150);
  digitalWrite (LEDpinlowred,0);
  digitalWrite (LEDpinmidred,0);
  digitalWrite (LEDpintopred,0);
  delay(400);
  digitalWrite (LEDpinlowred,1);
  digitalWrite (LEDpinmidred,1);
  digitalWrite (LEDpintopred,1);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  //iosController.loop();
  iosController.loop(500);
void doWork() {
  delay (1200); // Most useful for tuning, sensor read time
  if  (analogRead(2) > Trigger){
    (++CumulativeTotal);
  } // if condition is true add 1 to 'The cumulative total' which will be displayed to the seven segment display.
  else // do nothing
  if (analogRead(2) < 600) {
  if (analogRead(2) > 600) {
  delay(1);
  if  (analogRead(1) > Trigger)  {
  else// do nothing
  if (analogRead(1) < Trigger) {
  delay(1);
  if  (analogRead(0) > Trigger)  {
  }// if condition is true add 1 to 'The cumulative total' which will be displayed to the seven segment display.
  else// do nothing
  if (analogRead(0) < Trigger) {
  delay(10);
    delay(10000);
  if (CumulativeTotal > 20){
    digitalWrite (LEDpinStat, 1);
    Serial.println ("Total Product Loaded:-");
    Serial.println (CumulativeTotal);
  if (Serial.available()) {
    //read serial as a character
    char ser = Serial.read();
    switch (ser) {
    case '1':
      analogWrite(laserPin, 50);
    case '2':
      analogWrite(laserPin, 100);
    case '3':
      analogWrite(laserPin, 150);
    case '4':
      analogWrite(laserPin, 200);
    case '5':
      analogWrite(laserPin, 250);
    case '0':
      analogWrite(laserPin, 0);
    case 'c':
      (CumulativeTotal = 0);
    case '+':
    case '-':
      (--CumulativeTotal);
    case 'ul58':
      (CumulativeTotal = -58);
  void processOutgoingMessages() {
    iosController.writeMessage("Total",CumulativeTotal);
   * This function is called when the iOS device connects
  void deviceConnected () {
    digitalWrite(CONNECTIONPIN,HIGH);
   * This function is called when the iOS device disconnects
  void deviceDisconnected () {
    digitalWrite(CONNECTIONPIN,LOW);
There is alot of useless code there so let me trim it up. I think the problem is here somewhere
byte mac[] = {
 * IP info
void doWork();
begin.IOSController
  server.begin();
or maybe here
void doWork() {
or maybe here
Be easy on on me I am a complete newbie on ethernet and not exactly a pro with arduino and libraries
Thanks in advance
What errors does it give in the compiler?
also here are the error codes I have
FarmCount:25: error: expected constructor, destructor, or type conversion before 'void'
FarmCount:81: error: expected unqualified-id before '.' token
FarmCount.ino: In function 'void loop()':
FarmCount:171: error: 'iosController' was not declared in this scope
FarmCount.ino: In function 'void doWork()':
FarmCount:265: error: a function-definition is not allowed here before '{' token
FarmCount:280: error: a function-definition is not allowed here before '{' token
FarmCount:291: error: a function-definition is not allowed here before '{' token
this will solve some of the error, maybe not all
look for
two brackets doing nothing but throw errors.
begin.IOSController
What the heck is this?
