how do you work with the buffer output of this example file?
is it outputting a string, and if it is how do i even compare this to anything?
if(packetBuffer == "thing") { do stuff; } doesn't work, but that's what i'm trying to get to.
for an idiot who knows fuckall about C, it's great that the example works but i can't do anything with it besides print things out on the serial monitor. serial.println can handle whatever the buffer is but nothing else can. it'd be nice if there was anything else in the example about this.
Below is some client test code that captures what is sent back from the dyndns IP server. You would various String parsing functions to extract the IP address if desired.
//zoomkat 11-04-13
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test client GET
//for use with W5100 based ethernet shields
//remove SD card if inserted
//data from myIP server captured in readString
#include <SPI.h>
#include <Ethernet.h>
String readString;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // myIP server test web page server
EthernetClient client;
void setup(){
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
while(true);
Serial.println("client readString test 11/04/13"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(serverName, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET / HTTP/1.1"); //download text
client.println("Host: checkip.dyndns.com");
client.println("Connection: close"); //close 1.1 persistent connection
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
readString += c; //places captured byte in readString
//Serial.println();
client.stop(); //stop client
Serial.println("client disconnected.");
Serial.println("Data from server captured in readString:");
Serial.print(readString); //prints readString to serial monitor
Serial.println("End of readString");
Serial.println("==================");
readString=""; //clear readString variable
