ethernet web configuration
Hello, I have found the need to be able to configure my ethernet shield in a web server, I have found this piece of code
prog_char htmlx0[] PROGMEM = "<html><title>Arduino Ethernet Setup Page</title><body marginwidth=\"0\" marginheight=\"0\" ";
prog_char htmlx1[] PROGMEM = "leftmargin=\"0\" style=\"margin: 0; padding: 0;\"><table bgcolor=\"#999999\" border";
prog_char htmlx2[] PROGMEM = "=\"0\" width=\"100%\" cellpadding=\"1\" style=\"font-family:Verdana;color:#fff";
prog_char htmlx3[] PROGMEM = "fff;font-size:12px;\"><tr><td>&nbsp Arduino Ethernet Setup Page</td></tr></table>
PROGMEM const char *string_table0[] = {htmlx0, htmlx1, htmlx2, htmlx3};
prog_char htmla0[] PROGMEM = "<script>function hex2num (s_hex) {eval(\"var n_num=0X\" + s_hex);return n_num;}";
prog_char htmla1[] PROGMEM = "</script><table><form><input type=\"hidden\" name=\"SBM\" value=\"1\"><tr><td>MAC:";
prog_char htmla2[] PROGMEM = "<input id=\"T1\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT1\" value=\"";
prog_char htmla3[] PROGMEM = "\">.<input id=\"T3\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT2\" value=\"";
prog_char htmla4[] PROGMEM = "\">.<input id=\"T5\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT3\" value=\"";
prog_char htmla5[] PROGMEM = "\">.<input id=\"T7\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT4\" value=\"";
prog_char htmla6[] PROGMEM = "\">.<input id=\"T9\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT5\" value=\"";
prog_char htmla7[] PROGMEM = "\">.<input id=\"T11\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT6\" value=\"";
PROGMEM const char *string_table1[] = {htmla0, htmla1, htmla2, htmla3, htmla4, htmla5, htmla6, htmla7};
prog_char htmlb0[] PROGMEM = "\"><input id=\"T2\" type=\"hidden\" name=\"DT1\"><input id=\"T4\" type=\"hidden\" name=\"DT2";
prog_char htmlb1[] PROGMEM = "\"><input id=\"T6\" type=\"hidden\" name=\"DT3\"><input id=\"T8\" type=\"hidden\" name=\"DT4";
prog_char htmlb2[] PROGMEM = "\"><input id=\"T10\" type=\"hidden\" name=\"DT5\"><input id=\"T12\" type=\"hidden\" name=\"D";
prog_char htmlb3[] PROGMEM = "T6\"></td></tr><tr><td>IP: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT7\" value=\"";
prog_char htmlb4[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT8\" value=\"";
prog_char htmlb5[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT9\" value=\"";
prog_char htmlb6[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT10\" value=\"";
PROGMEM const char *string_table2[] = {htmlb0, htmlb1, htmlb2, htmlb3, htmlb4, htmlb5, htmlb6};
prog_char htmlc0[] PROGMEM = "\"></td></tr><tr><td>MASK: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT11\" value=\"";
prog_char htmlc1[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT12\" value=\"";
prog_char htmlc2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT13\" value=\"";
prog_char htmlc3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT14\" value=\"";
PROGMEM const char *string_table3[] = {htmlc0, htmlc1, htmlc2, htmlc3};
prog_char htmld0[] PROGMEM = "\"></td></tr><tr><td>GW: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT15\" value=\"";
prog_char htmld1[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT16\" value=\"";
prog_char htmld2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT17\" value=\"";
prog_char htmld3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT18\" value=\"";
prog_char htmld4[] PROGMEM = "\"></td></tr><tr><td>
</td></tr><tr><td><input id=\"button1\"type=\"submit\" value=\"SUBMIT\" ";
prog_char htmld5[] PROGMEM = "></td></tr></form></table></body></html>";
PROGMEM const char *string_table4[] = {htmld0, htmld1, htmld2, htmld3, htmld4, htmld5};
prog_char htmle0[] PROGMEM = "Onclick=\"document.getElementById('T2').value ";
prog_char htmle1[] PROGMEM = "= hex2num(document.getElementById('T1').value);";
prog_char htmle2[] PROGMEM = "document.getElementById('T4').value = hex2num(document.getElementById('T3').value);";
prog_char htmle3[] PROGMEM = "document.getElementById('T6').value = hex2num(document.getElementById('T5').value);";
prog_char htmle4[] PROGMEM = "document.getElementById('T8').value = hex2num(document.getElementById('T7').value);";
prog_char htmle5[] PROGMEM = "document.getElementById('T10').value = hex2num(document.getElementById('T9').value);";
prog_char htmle6[] PROGMEM = "document.getElementById('T12').value = hex2num(document.getElementById('T11').value);\"";
PROGMEM const char *string_table5[] = {htmle0, htmle1, htmle2, htmle3, htmle4, htmle5, htmle6};
for (int i = 0; i < 4; i++)
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table0[i])));
            client.print( buffer );
          for (int i = 0; i < 3; i++)
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[i])));
          client.print(mac[0],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[3])));
          client.print(mac[1],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[4])));
          client.print(mac[2],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[5])));
          client.print(mac[3],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[6])));
          client.print(mac[4],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[7])));
          client.print(mac[5],HEX);
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[i])));
          client.print(ip[0],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[4])));
          client.print(ip[1],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[5])));
          client.print(ip[2],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[6])));
          client.print(ip[3],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[0])));
          client.print(subnet[0],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[1])));
          client.print(subnet[1],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[2])));
          client.print(subnet[2],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[3])));
          client.print(subnet[3],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[0])));
          client.print(gateway[0],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[1])));
          client.print(gateway[1],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[2])));
          client.print(gateway[2],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[3])));
          client.print(gateway[3],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[4])));
          for (int i = 0; i < 7; i++)
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table5[i])));
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[5])));
I got it here http://www.jo3ri.be/arduino/projects/network-settings-web-page-form-using-eeprom-to-save-submit
However this only compiles with Arduino 1.0.6, due to prog_char being depreciated.
Any ideas?
• Changing prog_char causes more error, btw this is my first time with dealing around arduino web servers.
• I know putting it to a string is not a good idea, and it doesn’t have enough space for the uno
Any ideas?
instead of this example:
try this:
const char htmlx0[] PROGMEM = "<html><title>Arduino Ethernet Setup Page</title><body marginwidth=\"0\" marginheight=\"0\" ";
const char  htmlx1[] PROGMEM = "leftmargin=\"0\" style=\"margin: 0; padding: 0;\"><table bgcolor=\"#999999\" border";
const char  htmlx2[] PROGMEM = "=\"0\" width=\"100%\" cellpadding=\"1\" style=\"font-family:Verdana;color:#fff";
const char  htmlx3[] PROGMEM = "fff;font-size:12px;\"><tr><td>&nbsp Arduino Ethernet Setup Page</td></tr></table>
const char *const string_table0[] PROGMEM = {htmlx0, htmlx1, htmlx2, htmlx3};
Look carefully, especially at the last line.
@kazkaslengvo, do not cross-post. Threads merged.
