I’m trying to modify ProtectedLed sketch that i found.
I want to implement reboot option with relay. Need to get replay to turn on, then off one time with delay of a second. My current efforts to do that has not gone so well. Problem is that the on and off repeat is selfe 3 times.
I’m not so good with coding and I would be grateful for any help.
#include <EtherCard.h>
static byte mymac[] = { 0x00,0x01,0x01,0x01,0x01,0x01 };
static byte myip[] = { 192,168,1,13 }; // The IP board address.
static byte gwip[] = { 192,168,1,1 }; // The gateway router address.
static byte netmask[] = { 255, 255, 255, 0 }; // The subnet mask.
static byte dnsip[] = { 192, 168, 1, 1 }; // The DNS server address.
byte Ethernet::buffer[700];
const int led_pin = 8;
char* led_password = "david";
boolean led_status;
boolean reboot_status;
void setup () {
Serial.begin(57600);
Serial.println("Protected LED demo");
if (!ether.begin(sizeof Ethernet::buffer, mymac, 10))
Serial.println( "Failed to access Ethernet controller");
Serial.println("Ethernet controller initialized");
Serial.println( "Getting static IP.");
if (!ether.staticSetup(myip, gwip, netmask, dnsip)){
Serial.println( "could not get a static IP");
ether.printIp("IP Address:\t", ether.myip);
ether.printIp("Netmask:\t", ether.netmask);
ether.printIp("Gateway:\t", ether.gwip);
pinMode(led_pin, OUTPUT);
digitalWrite(led_pin, HIGH);
led_status = true;
word len = ether.packetReceive();
word pos = ether.packetLoop(len);
if(pos) {
boolean password_valid = true;
// is it a POST request?
if(strstr((char *)Ethernet::buffer + pos, "POST /") != 0) {
Serial.println("New POST request!");
// search and verify the password
char password[20];
char* password_position = strstr((char *)Ethernet::buffer + pos, "&pwd=");
if(password_position != 0) {
strcpy(password, password_position + 5);
Serial.print("Found password=");
Serial.println(password);
if(strcmp(password, led_password) == 0) Serial.println("Valid password :)");
else {
Serial.println("Wrong password :(");
password_valid = false;
// search for ON= or OFF= command
if(password_valid) {
// OFF command
if(strstr((char *)Ethernet::buffer + pos, "OFF=") != 0) {
Serial.println("Performing OFF command");
digitalWrite(led_pin, LOW);
led_status = false;
// ON command
} else if(strstr((char *)Ethernet::buffer + pos, "ON=") != 0) {
Serial.println("Performing ON command");
led_status = true;
// REBOOT command
} else if(strstr((char *)Ethernet::buffer + pos, "REBOOT=") != 0) {
Serial.println("Performing REBOOT command");
delay(1000); // waits for a second
reboot_status = true;
} else Serial.println("Unknown command :(");
// Output HTML page
BufferFiller bfill = ether.tcpOffset();
bfill.emit_p(PSTR("HTTP/1.0 200 OK\r\n"
"Content-Type: text/html\r\nPragma: no-cache\r\n\r\n"
"<html><head><title>Protected LED</title></head>"
<p><u><b><font size=7>NADZOR NAD RELEJI </font></b></u></p>
"<html><body><form method=\"POST\">"));
// Enable / disable buttons based on the output status
//if(led_status == true) bfill.emit_p(PSTR("<div><button name=\"ON\" disabled>ON</button><button name=\"OFF\">OFF</button></div>"));
if(led_status == true) bfill.emit_p(PSTR("<div><button name=\"ON\" disabled style=\"width: 120; height: 30\">ON</button></button><button name=\"REBOOT\" style=\"width: 120; height: 30\">REBOOT</button><button name=\"OFF\" style=\"width: 120; height: 30\">OFF</button></div>"));
else if(reboot_status == true) bfill.emit_p(PSTR("<div><button name=\"ON\" disabled style=\"width: 120; height: 30\">ON</button><button name=\"OFF\" style=\"width: 120; height: 30\">OFF</button></button><button name=\"REBOOT\" style=\"width: 120; height: 30\">REBOOT</button></div>"));
// else bfill.emit_p(PSTR("<div><button name=\"ON\">ON</button><button name=\"OFF\" disabled>OFF</button></div>"));
else bfill.emit_p(PSTR("<div><button name=\"ON\" disabled style=\"width: 120; height: 30\">ON</button><button name=\"OFF\" style=\"width: 120; height: 30\">OFF</button></button><button name=\"REBOOT\" style=\"width: 120; height: 30\">REBOOT</button></div>"));
// A wrong password was entered?
//if(password_valid == true) bfill.emit_p(PSTR("
<div><input type=\"password\" name=\"pwd\"></div></form></body></html>"));
<div><input name=\"pwd\" value=\"Pred spremembo vnesi geslo\" size=\"50\"></div></form></body></html>"));
<div><input type=\"password\" name=\"pwd\">Wrong password</div></form></body></html>"));
ether.httpServerReply(bfill.position());
This part of the code
// REBOOT command
does not work as I would like. Relay turns on and off 3x, Instead once.
I have tried to implement delay with millis() but I couldn’t make it work.
