Hi there,
I am trying to use the Wiz550io with my Arduino Zero board, using the Ethernet2 library. Unfortunately, I got the error message "Failed to configure Ethernet using DHCP". I am using the DhcpAddressPrinter example provided by the library. Is the Arduino Zero not compatible with the Wiz550io? Because I tried with the same example with the Arduino UNO and It worked fine.
Any thoughts?
Thanks!
