Hi guys,
I'd like to get some ideas for my troubleshooting-process.
Situation:
Months ago I edited the "Web-Server" communication sketch for the Ethernet-shield, to let my Arduino communicate with my server. Basically I send data via a HTTP GET-Request to my Arduino, get relevant information isolated and pass them on to other functions. So far this works pretty well, and therefor serves as my framework-sketch.
Since then I wrote two different sketches based on that communication-framework. As they are part of a project, I bought for each sketch a separate set of "Arduino Due + Ethernet-Shield". The first "set" was bought in October/November 2013 for the first sketch which controls a little wooden catapult. The second set was bought in February 2014 for the second sketch, which controls a little robot with seven servo-motors.
Problem:
Both of these two sketches work if I'm using the first/older set (catapult) with no cables and motors attached, but not if I'm using the second/newer set (robo): The Robo-Set executes the catapult-sketch properly, but not its own robo-sketch: Printing the incoming GET-Request of the server on the Serial Monitor, reveals that the connection to the server is somehow interrupted (?), as only parts of the request are printed:
arduino is at 123.345.678.900
*** New request from 1 :
GET / HTTP/1.1
Hoclient disconnected
st: 123.456client disconnected
As you can see, the request is split up and not complete. Sometimes I get more parts, sometimes less, but only a few times I get the whole request.
Now, this is how it should look like:
GET / HTTP/1.1
Host: 123.345.678.901
User-Agent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:27.0) Gecko/20100101 Firefox/27.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-US,en;q=0.5
Accept-Encoding: gzip, deflate
Connection: keep-alive
*** START: analyze HTTP-GET-Request
client disconnected
Possible Explanations:
if (client.connected()){ ... }
is set to FALSE before the whole request came in
- client "disconnects" too early because of memory-issues, due to the many variables which the Robo-sketch consists of.
- second Robo-"Arduino-set" has other firmware then the older one (either DUE or Shield) ?
- second Robo-"Arduino-set" has less available RAM
- RAM is somehow flawed
- damaged Board, DUE or Shield
Questions:
- Are there different versions of available firmware for the Arduino DUE or the Ethernet-Shield?
- How is it possible that one set works while the other one doesn't?
- How can I find out which part DUE or Shield is responsible for this misbehavior?
Additional Information:
I've got another (third) set of Due+Ethernet-Shield, to which I uploaded the Robo-Code when I got confronted with my problem the first time. As far as I remember it worked just once, maybe twice. But then I started mixing the shields and boards to find out which one was defect, and as a result this extra-set doesn't work with the Robo-Code anymore.
The one thing I've not been trying so far is to actually connect the catapult Arduino-Set to the robot-circuit. Why? Because I'm afraid that this "last-one-standing-board" could be damaged as well due to maybe an undetected bug in the robot-circuit.
The ROBO-Code is attached!
I'm really looking forward to your ideas, thanks.
ROBO_Sketch_Forum_Version.zip (6.31 KB)
