I have the arduino uno r3 connected with the ethernet shield. When I try to compile the example WebServer project (or any project from the Ethernet examples) I’m getting SPI compile errors.
On this board is also an SD card interface present, and the SD example is compiling (and running) just fine. I just can’t get to get the Ethernet examples to work. I have tried copying the library to the sketchbook folder, but no luck.
I’m using ARDUINO 1.0.1 - 2012.05.21 on ubuntu.
Is there something missing?
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp: In member function ‘void W5100Class::init()’:
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp:28: error: ‘delay’ was not declared in this scope
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp:30: error: ‘SPI’ was not declared in this scope
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp: In static member function ‘static uint8_t W5100Class::write(uint16_t, uint8_t)’:
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp:133: error: ‘SPI’ was not declared in this scope
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp: In static member function ‘static uint16_t W5100Class::write(uint16_t, const uint8_t*, uint16_t)’:
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp:146: error: ‘SPI’ was not declared in this scope
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp: In static member function ‘static uint8_t W5100Class::read(uint16_t)’:
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp:159: error: ‘SPI’ was not declared in this scope
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp: In static member function ‘static uint16_t W5100Class::read(uint16_t, uint8_t*, uint16_t)’:
/home/marek/sketchbook/libraries/Ethernet/utility/w5100.cpp:172: error: ‘SPI’ was not declared in this scope
