Hello everyone,
for a project i am working on i use the EthernetWebServer.h library to upload the code on the ESP32S3 via Ethernet using the W5500.
I used the same code earlier (in 2024 and it worked) but when now i try to compile it i get error messags which i'll post here.
I tried just to open new sketch and include the library (EthernetWebServer.h) but i get the same error.
I have already changed the member function :
virtual void begin( uint13_t port=0) =;
to:
void begin() {};
with no success.
Here is the error:
In file included from h:\Documents\Arduino\libraries\Ethernet_Generic\src/Ethernet_Generic_Impl.h:64,
from h:\Documents\Arduino\libraries\Ethernet_Generic\src/Ethernet_Generic.h:85,
from h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer.h:58,
from C:\Users\khalilm\AppData\Local\Temp\.arduinoIDE-unsaved202513-12756-16urj7s.th8k\sketch_feb3a\sketch_feb3a.ino:1:
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h:83:16: error: invalid abstract return type for member function 'EthernetClient EthernetServer::available()'
83 | EthernetClient EthernetServer::available()
In file included from h:\Documents\Arduino\libraries\Ethernet_Generic\src/Ethernet_Generic.h:84:
h:\Documents\Arduino\libraries\Ethernet_Generic\src/Ethernet_Generic.hpp:462:7: note: because the following virtual functions are pure within 'EthernetClient':
462 | class EthernetClient : public Client
In file included from C:\Users\khalilm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0-RC3\cores\esp32/Arduino.h:197,
from C:\Users\khalilm\AppData\Local\arduino\sketches\ACE1E3E06AEF3D379195357196C96B8F\sketch\sketch_feb3a.ino.cpp:1:
C:\Users\khalilm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0-RC3\cores\esp32/Client.h:29:15: note: 'virtual int Client::connect(IPAddress, uint16_t, int32_t)'
29 | virtual int connect(IPAddress ip, uint16_t port, int32_t timeout) = 0;
C:\Users\khalilm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.0-RC3\cores\esp32/Client.h:31:15: note: 'virtual int Client::connect(const char*, uint16_t, int32_t)'
31 | virtual int connect(const char *host, uint16_t port, int32_t timeout) = 0;
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h: In member function 'EthernetClient EthernetServer::available()':
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h:93:39: error: invalid cast to abstract class type 'EthernetClient'
93 | return EthernetClient(MAX_SOCK_NUM);
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h:138:34: error: invalid cast to abstract class type 'EthernetClient'
138 | return EthernetClient(sockindex);
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h: At global scope:
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h:143:16: error: invalid abstract return type for member function 'EthernetClient EthernetServer::accept()'
143 | EthernetClient EthernetServer::accept()
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h: In member function 'EthernetClient EthernetServer::accept()':
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h:153:39: error: invalid cast to abstract class type 'EthernetClient'
153 | return EthernetClient(MAX_SOCK_NUM);
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h:190:34: error: invalid cast to abstract class type 'EthernetClient'
190 | return EthernetClient(sockindex);
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h: In member function 'virtual size_t EthernetServer::write(const uint8_t*, size_t)':
h:\Documents\Arduino\libraries\Ethernet_Generic\src/EthernetServer_Impl.h:409:12: error: cannot allocate an object of abstract type 'EthernetClient'
409 | available();
In file included from h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer.h:67:
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer.hpp: At global scope:
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer.hpp:578:23: error: cannot declare field 'EthernetWebServer::_currentClient' to be of abstract type 'EthernetClient'
578 | EthernetClient _currentClient;
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer.hpp:376:20: error: invalid abstract return type for member function 'EthernetClient EthernetWebServer::client()'
376 | EthernetClient client()
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer.hpp: In member function 'EthernetClient EthernetWebServer::client()':
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer.hpp:378:14: error: cannot allocate an object of abstract type 'EthernetClient'
378 | return _currentClient;
In file included from h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer.h:68:
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer-impl.h: In member function 'void EthernetWebServer::handleClient()':
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer-impl.h:243:46: error: cannot allocate an object of abstract type 'EthernetClient'
243 | EthernetClient client = _server.available();
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer-impl.h:243:20: error: cannot declare variable 'client' to be of abstract type 'EthernetClient'
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer-impl.h:319:37: error: invalid cast to abstract class type 'EthernetClient'
319 | _currentClient = EthernetClient();
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer-impl.h: In member function 'void EthernetWebServer::serveStatic(const char*, fs::FS&, const char*, const char*)':
h:\Documents\Arduino\libraries\EthernetWebServer\src/EthernetWebServer-impl.h:862:26: error: expected type-specifier before 'StaticFileRequestHandler'
862 | _addRequestHandler(new StaticFileRequestHandler(fs, path, uri, cache_header));
So please if someone had encountered such situation and manage to fix it, help me to fix it too.
Thanks in Advance
