- The following is the sample terminal output when running example WebClient_SSL on NUCLEO_F767ZI with W5x00 & Ethernet3 Library
Start WebClient_SSL on NUCLEO_F767ZI with W5x00 & Ethernet3 Library
[ETHERNET_WEBSERVER] =========== USE_ETHERNET3 ===========
[ETHERNET_WEBSERVER] Default SPI pinout:
[ETHERNET_WEBSERVER] MOSI: 11
[ETHERNET_WEBSERVER] MISO: 12
[ETHERNET_WEBSERVER] SCK: 13
[ETHERNET_WEBSERVER] SS: 10
[ETHERNET_WEBSERVER] =========================
[ETHERNET_WEBSERVER] Board : NUCLEO_F767ZI , setCsPin: 10
Ethernet3 W5500 init, using SPI_CS = 10, number of sockets = 4
Currently Used SPI pinout:
MOSI:11
MISO:12
SCK:13
SS:10
SPI_CS:10
Using mac index = 10
Connected! IP address: 192.168.2.139
Connecting to : www.arduino.cc, port : 443
Connected to www.arduino.cc
Took: 421
HTTP/1.1 200 OK
Date: Tue, 10 Nov 2020 08:42:12 GMT
Content-Type: text/plain
Transfer-Encoding: chunked
Connection: close
Set-Cookie: __cfduid=dc0d46f4fc488c76630a1c7327c64d5861604997732; expires=Thu, 10-Dec-20 08:42:12 GMT; path=/; domain=.arduino.cc; HttpOnly; SameSite=Lax
Last-Modified: Wed, 02 Oct 2013 13:46:47 GMT
Vary: Accept-Encoding
Access-Control-Allow-Origin: https://www.arduino.cc
Access-Control-Allow-Credentials: true
Access-Control-Allow-Methods: GET, POST, PUT, DELETE, OPTIONS
Access-Control-Allow-Headers: Accept,Authorization,Cache-Control,Content-Type,DNT,If-Modified-Since,Keep-Alive,Origin,User-Agent,X-Mx-ReqToken,X-Requested-With
Strict-Transport-Security: max-age=500; includeSubDomains
X-Frame-Options: SAMEORIGIN
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
CF-Cache-Status: DYNAMIC
cf-request-id: 0652eaf1aa0000cabc368f8000000001
Expect-CT: max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"
Server: cloudflare
CF-RAY: 5efe7a95dacecabc-YYZ
alt-svc: h3-27=":443"; ma=86400, h3-28=":443"; ma=86400, h3-29=":443"; ma=86400
8d7
.;;;;;;;;;;;` :;;;;;;;;;;: TM
0
(EthernetSSLClient)(SSL_WARN)(connected): Socket was dropped unexpectedly (this can be an alternative to closing the connection)
Disconnecting.
Received 3405 bytes in 0.4360 s, rate = 7.81 kbytes/second
