Hi, I've just recently bought an Etherten, and plugging it in today and loading up a webserver tutorial, I have a problem. I've got no network lights on the board or the switch. I've tried different leads and ports. I used this http://arduino.cc/en/Tutorial/WebServer tutorial. Any suggestions? Thanks,
yeah i had the same problem if powering it only from USB, worked ok once i plugged it in to a powerpoint.
guy at jaycar tells me his works only if he uses one of those USB splitter cables that plug into two USB ports at once.
i'd guess there's just not enough power coming through on the USB port - i tried it on a couple of different machines and they all suffered the same thing
