ethnet shield and big page html to send
Dear all, I expexct I write this question in the good forum.
I would like to write a big web page to send to a client. I use the library ETHER_28J60 (this is the ethernet shiels connected : http://www.dipmicro.com/store/ENC28J60-MINI-MOD)
So, I create my answer like that:
ETHER_28J60 ethernet; // creating the client ethernet.print("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n");// Creating the answer ethernet.print("..."); //etc ... ethernet.print("..."); //etc ... ethernet.print("..."); // etc ...
When the answer is bigger that 500 bytes (aproximately), the answer is not made. I think there is a buffer somewhere which limit the answer size.
So, I would like to know if there is any functions which permit to generate a "Big" answer.
Thanks a lot for your help.
Hi, i don't use this library, but the "normal" ethernetshield.
You should not use the ethernet.print("...");
Please use instead:
  1. define a array: char buffer [256];
  2. fill the array: strcpy(buffer, "...");
  3. write the array: ethernet.write(buffer);
Because with the print command you send one packet per char, with the write command you can send many chars with 1 packet, the header-overhead is very reduced.
paulinchen
OK, I can try what you say, but I don't understand how I can send more than the 256 char of the buffer ? I have another problem : my shield does not work with the library ethernetshiels, or I do not use it well.
You can make the buffer bigger or you can send also more than 1 buffer:
char buffer [256];
strcpy(buffer, "..."); ethernet.write(buffer); strcpy(buffer, "..."); ethernet.write(buffer); strcpy(buffer, "..."); ethernet.write(buffer); ...
paulinchen
I have made a buffered printer class snippet for doing this automatically. It will allow you to still use print/println so you do not need to use strcpy to build strings.
The little snippet above becomes:
char buffer [256];
BufferedPrinter Buff( ethernet, buffer, 256 );
Buff.print( "..." );
Buff.flush();
You only need to call flush at the end. When the buffer is filled through normal printing it will be written out as one chunk automatically ( calls x.write() ).
The best part is print/println support a lot of conversions (integer/float) and the ability to print from PROGMEM. Loosing that functionality removes a significant ease of use.
Here is the class ( I just modified it for large sized buffers ):
class BufferedPrinter : public Print{
  public:
    BufferedPrinter( Print &p_Out, uint8_t *u_Buff, int i_Len ) : Output( p_Out ), Buff( u_Buff ), Cursor( 0x00 ), Max( i_Len ) {}
    ~BufferedPrinter( void ) { flush(); }
    void flush()
        if( Cursor )
          Output.write( Buff, Cursor );
        Cursor = 0x00;
    size_t write( uint8_t u_Data )
        if( Cursor == Max ){
          Cursor = 0x00;
        Buff[ Cursor++ ] = u_Data;
        return 0x01;
  protected:
    Print &Output;
    uint8_t *Buff;
    int Cursor;
    int Max;
Thanks all for your answers. But I think your solutions are not able with my ethernet hardware.
I found a solution described here for these who will need the same thing: install the library https://github.com/ntruchsess/arduino_uip : it is compatible with the Enc28J60 http://www.dipmicro.com/store/ENC28J60-MINI-MOD
