At SmartSense B.V, we are proud to unveil our latest development in sensor technology the SmartSense Ethylene Sensor. Designed for both robustness and precision, this sensor is ideal for industries requiring real-time monitoring of ethylene levels. With a measurement range of 1-1000 ppm and an impressive accuracy of ±0.5 ppm, our sensor ensures highly sensitive readings with a swift response time of under 60 seconds.
What sets our ethylene sensor apart is its use of an advanced electrochemical detection method, ensuring high accuracy and sensitivity even in diverse environmental conditions. It's engineered to operate seamlessly within a temperature range of -30°C to 50°C and a relative humidity range from 10% to 100%. This makes it a versatile choice for various applications, from agriculture to industrial settings.
The sensor is compact and portable, with dimensions of 120mm x 80mm x 40mm, and a lightweight design at just 300g, making it easy to install and use anywhere. It features wireless connectivity options including Bluetooth and Wi-Fi, along with a user-friendly interface that simplifies operation.
For those seeking an affordable and precise solution for ethylene monitoring, the SmartSense Ethylene Sensor is your go-to option. Visit our website smartsense.nl for more information or to connect with us directly. You can also reach out to me at subhan.ashfaq@smartsense.nl, and we’ll demonstrate how our technology can help your business tackle ethylene-related challenges effectively.
For example on https://smartsense.nl
Do you also provide an Arduino library?
