Brethren I seek your assistance, for I have lost all my hair.
I am building a DIY sequencer from,
And running into issues with its behaviour.
I have rebuild the PCB twice, tried two different nano's, no shorts or dry solder joints and checked all the components, but still the problem persists.
The colours are all out of whack and it doesn't scroll the selection as intended. It's feral.....
I didn't have any issues with the sketch or uploading it to the nano's.
Any help or ideas as to why it's acting so strangely would be much appreciated.
// Code written by David Wieland aka Datulab Tech. Feel free to use this in your own projects and improve upon it. If you make
// something cool, please let me know. This code has been written specifically for the Arduino nano and RGBW Neopixel LEDs.
// If you want to use a differetn configuration, make sure to update the code.
// C++ is not my main programming language, so please excuse if the code could be a bit nicer in some areas.
// If you have any questions, make sure to check out the video on my YouTube channel about this.
// If there still is anything, write me a message to info@datulab.tech
#include <EEPROM.h>
//Initializing the LEDs
Adafruit_NeoPixel strip = Adafruit_NeoPixel(16, 13, NEO_GRBW + NEO_KHZ800);
//Settings
#define whiteBrightness 15
#define voicePin A2
#define bpmPin A1
#define patternPin A0
#define syncPin A7
#define numPatterns 5 //number of patterns including one random
#define patternChangeDuration 1000 //how long pattern change is displayed
#define minBpm 20 //sets minimum bpm
#define bpmScale 3 //ratio bpm above min is scaled with, at 3 bpm scales from 20 - 360
#define trigDuration 10 //time in ms that trigger is high
//Switch matrix variables
byte inputs[] = {6, 7, 8, 9, 10};
const byte inCount = sizeof(inputs) / sizeof(inputs[0]);
byte outputs[] = {2, 3, 4, 5};
const byte outCount = sizeof(outputs) / sizeof(outputs[0]);
const byte outputPins[] = {17, 18, 19, 20};
//State variables
bool lengthSelect;
bool trig;
bool sync;
int bpm = 120;
byte voice = 0;
byte pattern = 0;
bool beat[4 * numPatterns][16]; //[4 voices numPatterns (minus random pattern) patterns][16 beats] true for hit false for no hit
byte lengths[4 * (numPatterns - 1)]; //length 1-15 of the voices
byte gateLength = 14; //length of the gate output relative to the beat length (0-15)
//Temporary variables
byte pos;
byte saveSlot;
bool stateChanged;
uint32_t currentColor;
bool isActive[16];
int patternPot = 1025;
int previousPatternPot;
int voicePot;
int bpmPot;
bool gateChange;
bool patternChange;
bool syncHigh;
//Timing variables
unsigned long currentTime; //saves current time
unsigned long previousBeat; //time of last beat change
unsigned long previousPatternTime; //time of patternChange engage
long beatDuration;
long gateDuration;
byte currentBeat[numPatterns];
//Colors
byte voiceColor[4][4] = {{30, 10, 0, 0},
{50, 0, 2, 0},
{5, 0, 30, 0},
{0, 25, 10, 0}};
// -------------------------------------------- Initial Setup ----------------------------------------------------------------
for(int i=0; i<outCount; i++){ //Initializes all the switch matrix pins
pinMode(outputs[i],OUTPUT);
digitalWrite(outputs[i],HIGH);
for(int i=0; i<inCount; i++){
pinMode(inputs[i],INPUT_PULLUP);
pinMode(syncPin, INPUT);
pinMode(voicePin, INPUT);
pinMode(bpmPin, INPUT);
pinMode(patternPin, INPUT);
Serial.begin(9600); //Establishes connection to computer for debuging
Serial.println("Connected");
strip.begin(); //Initializes the LEDs and displays light show
for(int i = 0; i < 16; i++){
strip.setPixelColor(i, i * 4, 40 - 2 * i, 20 - i, 0);
strip.show();
delay(50);
//reading variables from EEPROM
int value = 0; //overcomplicated way of finding the next save location
int previousValue = 0;
int startAddress = 64;
for(int i = 0; i < 16; i++){ //finds newest starting address by comparing first byte of all locations
value = EEPROM.read(i * 64);
if(value == previousValue + 1 || previousValue == 255 || (i == 0 && value != 0)){
previousValue = value;
startAddress = i * 64;
gateLength = EEPROM.read(startAddress + 1); //reads the gate length
for(int pat = 0; pat < 4; pat++){ //the 2 nested for loops iterate through the patterns and voices
for(int voi = 0; voi < 4; voi++){
int voiceStart = startAddress + 2 + 3 * (voi + 4 * pat); //starting address of voice
int beat1 = EEPROM.read(voiceStart); //the 2 integers are converted back to 16 bool values
for(int i = 0; i < 8; i++){
if(beat1 / (1 << (7 - i)) > 0){
beat[voi + 4 * pat][7 - i] = true;
beat1 = beat1 - (1 << (7 - i));
}else{
beat[voi + 4 * pat][7 - i] = false;
int beat2 = EEPROM.read(voiceStart + 1);
if(beat2 / (1 << (7 - i)) > 0){
beat[voi + 4 * pat][15 - i] = true;
beat2 = beat2 - (1 << (7 - i));
}else{
beat[voi + 4 * pat][15 - i] = false;
lengths[voi + 4 * pat] = EEPROM.read(voiceStart + 2); //reading the length value
// -------------------------------------------- Reading the switches ---------------------------------------------------------
void readSwitches(){ //Reading the switches and updating the beat, lengths, lengthSelect, gate, and sync variables with the current switch states
saveSlot = voice + 4 * pattern;
for (int i = 0; i < 4; i++){ //iterates through the 4 outputs
digitalWrite(outputs[i],LOW);
delayMicroseconds(5);
for(int j = 0; j < 5; j++){ //iterates throught the 5 inputs
bool state; //state of current switch
if(digitalRead(inputs[j])){
state = false;
}else{
state = true;
pos = 4 * j + i; //current switch number
if(j < 4 && voice != 4){ //if on one of the beat switches
if(lengthSelect && state){ //if in length selecting mode
lengths[saveSlot] = pos;
stateChanged = true;
} //otherwise if switch is newly engaged
else if(state && !isActive[pos]){
beat[saveSlot][pos] = !beat[saveSlot][pos];
isActive[pos] = true;
} //resetting isActive if switch newly disengaged
else if(!state && isActive[pos]){
isActive[pos] = false;
else if (j == 4){ //if on one of the settings switches
switch(i){
case 0:
lengthSelect = state;
case 1:
trig = state;
case 2:
sync = state;
// -------------------------------------------- Reading the Pots -------------------------------------------------------------
void readPots(){ //Reads pots and updates variables bpm, voice, pattern, and gate length with the current pot positions
patternPot = analogRead(patternPin); //reads pots
bpmPot = analogRead(bpmPin);
voicePot = analogRead(voicePin);
if(patternPot < previousPatternPot - 5 || patternPot > previousPatternPot + 5){ //if pattern pot has been changed
if(previousPatternPot != 1025){
patternChange = true; //patternChange will switch LEDs to display pattern or gate length
previousPatternTime = millis();
if(lengthSelect){ //if in lenghth selecting mode
gateLength = patternPot / 48; //sets gateLength to a 0-15 number according to pattern pot
gateChange = true;
else{ //if in normal operating mode
pattern = patternPot * numPatterns / 1024; //updates the pattern with pos of pattern pot
previousPatternPot = patternPot;
beatDuration = 60000 / (bpm * 4); //updates beatDuration with current bpm value
gateDuration = beatDuration * gateLength / 16; //updates gateDuration with current beatDuration and gateLength
bpm = minBpm + bpmPot / bpmScale;
voice = voicePot * 5 / 1024;
// -------------------------------------------- Updating the LEDs ------------------------------------------------------------
void displayLEDs(){
if(lengthSelect && voice != 4){ //if length switch is active
if(patternChange){ //gate length selection mode, represents relative gate length with red leds
if(i <= gateLength){
strip.setPixelColor(i, 50, 0, 0, 0);
}else{
strip.setPixelColor(i, 0, 0, 0, 0);
else if(voice != 4){ //length selection mode, turns all active beats white and others off
if(i <= lengths[saveSlot]){
strip.setPixelColor(i, 0, 0, 0, 15);
}else{
else if(patternChange){ //if pattern has been changed recently, pattern nr is displayed with led
if(i == pattern){
}else{
else{ //normal operating mode, shows active beats in color of voice, turns others off
if(voice != 4){ //if in voice editing mode
if(beat[saveSlot][i]){ //displays active beats for current voice
strip.setPixelColor(i, voiceColor[voice][0], voiceColor[voice][1], voiceColor[voice][2], voiceColor[voice][3]);
else{
else{ //if in performance mode, all voices are displayed with voice 1 as highest priority
for(int j = 0; j < 4; j++){
if(beat[3 - j + 4 * pattern][i]){
strip.setPixelColor(i, voiceColor[3 - j][0], voiceColor[3 - j][1], voiceColor[3 - j][2], voiceColor[3 - j][3]);
for(int i = 0; i < 16; i++){ //highlights current beat
if(currentBeat[voice] == i){
strip.setPixelColor(i, 0, 0, 0, 25);
strip.show();
// -------------------------------------------- Generates random beat --------------------------------------------------------
void randomBeat(){ //creates a random beat for all 4 voices with voice 1 the most beats and voice 4 the fewest
for(int i = 0; i < 4; i++){
for(int j = 0; j < 16; j++){
if(random(10) > 4 + i){
beat[16 + i][j] = true;
}else{
beat[16 + i][j] = false;
// -------------------------------------------- Updates the beat -------------------------------------------------------------
void advanceBeat(){ //updates currentBeat, if it reached end for a voice it rolls over to first beat
if(pattern != 4){
for(int i = 0; i < 5; i++){
if(i < 4){
if(currentBeat[i] < lengths[i + 4 * pattern]){
currentBeat[i]++;
}else{
currentBeat[i] = 0;
}else{
if(currentBeat[i] < lengths[0 + 4 * pattern]){
currentBeat[i]++;
}else{
currentBeat[i] = 0;
else{ //if on random pattern, new pattern is generated when beat rolls over to first position
if(currentBeat[0] < 15){
currentBeat[0]++;
}else{
currentBeat[0] = 0;
randomBeat();
currentBeat[i + 1] = currentBeat[0];
// -------------------------------------------- Updates the outputs ----------------------------------------------------------
void output(){
if(!trig && previousBeat + gateDuration > currentTime){ //if in gate mode and during active gate time
digitalWrite(outputPins[i],beat[saveSlot][currentBeat[i]]);
else if(trig & previousBeat + trigDuration > currentTime){ //if in trig mode and during acrive trig time
else{ //if not in active time, outputs are low
digitalWrite(outputPins[i],LOW);
// -------------------------------------------- Checks time ------------------------------------------------------------------
void checkTiming(){ //checks if enough time has passed to advance to the next beat
currentTime = millis(); //gets current time in ms
if(currentTime - previousBeat >= beatDuration){ //if it is time for new beat
previousBeat = currentTime;
if(!sync){
advanceBeat();
if(patternChange && currentTime - previousPatternTime >= patternChangeDuration){ //if enough time has passed since pattern pot was last moved, returning to normal LED display
patternChange = false;
if(gateChange){ //if gate length has changed, causes EEPROM write
gateChange = false;
// -------------------------------------------- Checks Sync Input ------------------------------------------------------------
void checkSync(){ //advances the beat on every rising flank of the sync input
if(analogRead(syncPin) > 600){
if(!syncHigh){
syncHigh = true;
advanceBeat();
else{
syncHigh = false;
// -------------------------------------------- Writes to EEPROM -------------------------------------------------------------
//Writes current beat patterns to EEPROM
//beat patterns are converted to 2byte per voice
//order is 1byte gate length, then repeated for each voice of each pattern 2byte pattern, 1byte length
//as writes are rated to 100'000, location is moved by increment of 64byte every time to use EEPROM uniformally
//to find newest entry, first byte is incremented (rolls over at 255), so looking for highest number will get newest
void writeEEPROM(){
stateChanged = false;
value = EEPROM.read(i*64);
if(i < 15){
startAddress = (i + 1) * 64;
}else{
startAddress = 0;
int index = 0;
if(previousValue != 255){
index = previousValue + 1;
EEPROM.update(startAddress,index); //writes counter to first byte
EEPROM.update(startAddress+1,gateLength); //writes gateLength to second byte
int beat1 = 0; //the 16 bool values for the beats get converted to 2 integers
if(beat[voi + 4 * pat][i]){
beat1 = beat1 + (1 << i);
int beat2 = 0;
if(beat[voi + 4 * pat][8+i]){
beat2 = beat2 + (1 << i);
int voiceStart = startAddress + 2 + 3 * (voi + 4 * pat); //writing the two integers of the beats and the length to EEPROM
EEPROM.update(voiceStart, beat1);
EEPROM.update(voiceStart + 1, beat2);
EEPROM.update(voiceStart + 2, lengths[voi + 4 * pat]);
// -------------------------------------------- Main Loop --------------------------------------------------------------------
readPots();
readSwitches();
if(stateChanged){
writeEEPROM();
displayLEDs();
checkTiming();
if(sync){
checkSync();
output();
type or paste code here
