I am running Arduino IDE 2.0.0 using version 3.3.0 of the Arduino Mbed OS Portenta Boards package. My build environment in macOS version 12.6 on a M2 based Mac. I have tried building and uploading the basic empty sketch that comes up when I first open the IDE and also the Blinky example. They both cause the blinking RED light of death immediately after upload.
If I attach GDB via JLink then I see the following callstack:
(gdb) bt
#0 0x0804a826 in _wait_us_ticks ()
#1 0x0804980c in mbed_die ()
#2 0x08049940 in mbed_halt_system ()
#3 0x08049c4a in mbed_error ()
#4 0x08049714 in mbed_assert_internal ()
#5 0x08052faa in pin_function ()
#6 0x080517ea in USBPhyHw::init(USBPhyEvents*) ()
#7 0x0804730e in USBDevice::init() ()
#8 0x08047360 in USBDevice::connect() ()
#9 0x08041f1c in main ()
at /Users/user/Library/Arduino15/packages/arduino/hardware/mbed_portenta/3.3.0/cores/arduino/main.cpp:40
I do see the following odd message when I turn verbose compile messages on:
/Users/user/Library/Arduino15/packages/arduino/hardware/mbed_portenta/3.3.0/bootloaders/PORTENTA_H7/portentah7_bootloader_mbed_hs_v2.elf syntax error: no colon char on the first line character at line 1
It has been awhile since I last used my Portenta H7 board, probably 2020.
Hopefully someone here can set me in the right direction to get this working again.
