Even my Teacher can't help me with our project!
Hello,
I became familiar with Arduino through a school project two weeks ago. My partner and I are currently working on a “shutter control”. As our code doesn’t work as it should and my teacher got no idea what we did wrong , we are asking you guys to help us.
What we got:
  • Arduino Uno
  • Stepper
  • Photoresistor
int eingang=A1;
// Analogport 1
int oben;
int unten=1;
int  rollo;
int sensorWert = 0;
#include <Stepper.h>
int SPMU = 32;
Stepper myStepper(SPMU, 2,3,4,5);
// 2,3,4,5, sind die Steckplätze
myStepper.setSpeed(500);
sensorWert=analogRead(eingang);
Serial.print("Sensorwert =");
Serial.println(sensorWert);
if(sensorWert<600)
int rollo = 0;
int rollo = 1;}
switch (unten) {
case 1:
        switch (rollo) {
        case 0:
        case 1:
        myStepper.step(2048);
        oben = 1;
        unten = 0;
        break;}
switch (oben) {
case 1:
        switch (rollo){
        case 0:
        myStepper.step(-2048);
        oben=0;
        unten=1;
	      case 1:
What it should do:
Turn the blinds up if it’s bright outside and then stop doing anything until it’s dark again, when it should turn them back down.
Clarification
oben = up
unten = down
Sensorwert = sensor value
Thank you for your attention. Have a great day.
Greetings Lizraya
Look at the scope of all the variables called "rollo"
In your code:
if(sensorWert<600)
   int rollo = 0;             // rollo #1 comes to life here
   int rollo = 1;             // rollo #2 comes to life here
}         // When execution gets to this line, both rollo #1 and #2 die.
you have defined two version of rollo. However, both are defined within the if statement block. There is a C programming concept called scope that determines the life and visibility of a variable. Try changing your code to:
int rollo;
if(sensorWert<600)
   rollo = 0;
   rollo = 1;
and see what happens.
It worked ! But serously that was a silly mistake of mine.
I appreciate your quick help. I'm very thankful.
Greetings Lizraya
One that you are not likely to repeat, are you? A learning experience is a good thing.
lizraya:
Also a very valuable learning experience
...R
