Event code, can't sleep arduino for correct amount of time
So i have had produced this code, but i cannot seem to sleep my Arduino Uno for my desired time. I need the Arduino Uno to sleep for 12 minutes, wake up and take readings after 3 minutes (warm up time for my sensors), then take readings for 5 minutes. I have got the wake up and reading times correct, just can't seem to get sleep time correct.
Can anyone help? These are the snippets of code that conrol the time:
const unsigned long eventInterval = (1000UL*60*3);   //Assign the time in millis for event interval (every 15 minutes)
unsigned long startTime =  millis()+ eventInterval;
unsigned long readingInterval= (1000UL*60*5);             //Assign the time in millis for reading (every 5 minutes)
//SD stack select
const int chipSelect = 10;
//const int pingPin = 7;
//RTC Module Global Variables
const int time_interval= 12 ;  // Sets the wakeup interval in minutes.
....and.....
    /* This is the event */
 if ((long)(millis()-startTime)>=0) {
  delay(10);
  unsigned long i=millis();
  while ((long)((i+readingInterval)-millis())>=0){
  //Get the values of the sensors
  GetRTC_Readings();
  GetVOC_Readings();
  GetPM_Readings();
  GetBME_Readings();
  delay (5000); // to give time for PMS to take readings?
  // Store the three sensor values to the SD card.
  print2SD();
  delay(5000);
  digitalWrite(indicator,HIGH);
  delay(2000);
  digitalWrite(indicator,LOW);
  Serial.println("Going to sleep for 24 seconds");
  digitalWrite(Relay_pin,LOW);
  digitalWrite(Relay_pin2,LOW);
  delay(100);
  for(int i = 0; i<= 6*time_interval; i++) //this is sleeping arduino for 12 seconds
  LowPower.idle(SLEEP_8S, ADC_OFF, TIMER2_OFF, TIMER1_OFF, TIMER0_OFF,SPI_OFF, USART0_OFF, TWI_OFF);
  startTime = millis()+ eventInterval; //this is what affects the time
  Serial.println("Arduino: Hey I just Woke up");
  Serial.println("");
Full code below:
//********************Start of code for TPH, PM, VOC sensor***********************
//*** TO DO LIST ***//
//pinmap with relay
//documentation
//- Calibrate BME
//- Calibrate VOC sensor (potentiometer on back adjusts zero threshold)
#include <RtcDS3231.h>
#include <DS3232RTC.h>
#include <LowPower.h>
#include <Adafruit_BusIO_Register.h>
#include <Adafruit_I2CDevice.h>
#include <Adafruit_I2CRegister.h>
#include <Adafruit_SPIDevice.h>
#include <avr/sleep.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <SoftwareSerial.h>
#include "Adafruit_PM25AQI.h"
#include <BME280I2C.h>
#include <SPI.h>
#include <SD.h>
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
//Real Time Clock
DS3232RTC rtc;
//BME280 - TPH
BME280I2C bme;
//PM Sensor
SoftwareSerial pmsSerial(3,4);
Adafruit_PM25AQI aqi = Adafruit_PM25AQI();
//#define 2
//TVOC sensor
#define Aout A0 //Define pins for TVOC sensor
#define Dout 7
//Set up pin 9
#define Relay_pin 9
#define Relay_pin2 6
uint32_t delayMS;
//eventinterval is when the arduino starts taking readings from sensos
//then redinginterval is how long the reading of sensor values happens
//time_interval is how long the arduino sleeps for
//meaning there will be a 3 minute warm up period for PMS and CJMCU-MS1100 until the next reading event
//SD stack select
unsigned int rtcd;
unsigned int rtcm;
unsigned int rtcy;
unsigned int rtcs;
unsigned int rtcmin;
unsigned int rtchr;
// Structure to hold pms sensor data.
struct pms5003data {
volatile uint16_t framelen;
volatile  uint16_t pm10_standard, pm25_standard, pm100_standard;
volatile  uint16_t pm10_env, pm25_env, pm100_env;
volatile  uint16_t particles_03um, particles_05um, particles_10um, particles_25um, particles_50um, particles_100um;
volatile  uint16_t unused;
volatile  uint16_t checksum;
} pms5003dataStruct;
  //Declaring BME variables
  float preshpa;
  float corr_temp;
  float corr_hum;
  float corr_preshpa;
  // Declaring VOC variables
  byte a;
  byte b;
  #define interruptPin 2
  #define indicator 8
  PM25_AQI_Data data;
pinMode(Relay_pin, OUTPUT);
pinMode(Relay_pin2, OUTPUT);
digitalWrite(Relay_pin,HIGH);
digitalWrite(Relay_pin2,HIGH);
  pinMode(indicator,OUTPUT);
 // pinMode(interruptPin, INPUT_PULLUP);
  digitalWrite(indicator, LOW);
  //Serial.begin(9600);
  // PM sensor debugging output
  while (!Serial) delay(10);
  // PM sensor baud rate is 9600
  pmsSerial.begin(9600);
//remember to copy and paste the RTC code from other code to reset RTC to current time!
//delay(1000);
//Find PM sensor
  if (! aqi.begin_UART(&pmsSerial)) { // connect to the sensor over software serial
    Serial.println(F("Could not find PM 2.5 sensor!"));
    while (1) delay(10);
  Serial.println(F("PM25 found!"));
//Find BME280 TPH sensor
  while (!bme.begin())
    Serial.println(F("Could not find BME280 sensor!"));
  //  delay(1000);
  // bme.chipID(); // Deprecated. See chipModel().
  switch (bme.chipModel())
    case BME280::ChipModel_BME280:
      Serial.println(F("Found BME280 sensor! Success."));
    case BME280::ChipModel_BMP280:
      Serial.println(F("Found BMP280 sensor! No Humidity available."));
    default:
      Serial.println(F("Found UNKNOWN sensor! Error!"));
  // Storing the CSV file header/title.
  printHeader();
  delay(10);
  GetRTC_Readings();
  GetVOC_Readings();
  GetPM_Readings();
  GetBME_Readings();
  print2SD();
  delay(5000);
  delay(2000);
  delay(100);
  for(int i = 0; i<= 6*time_interval; i++) //this is sleeping arduino for 24 seconds
  Serial.println("");
 void printHeader(){
//Initialize and find SD card
  Serial.print(F("Initializing SD card..."));
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println(F("Card failed, or not present"));
    // don't do anything more:
    while (1);
  Serial.println(F("card initialized."));
   File dataFile = SD.open("datalog.csv", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    //dataFile.print(cm);        dataFile.print(",CM,");
    dataFile.print("DATE,");
    dataFile.print("TIME,");
    dataFile.print("Temperature,");
    dataFile.print("Pressure,");
    dataFile.print("Humidity,");
    dataFile.print("TVOC Digital,");
    dataFile.print("TVOC Analogue,");
    dataFile.print("PM 0.3,");
    dataFile.print("PM 2.5,");
    dataFile.print("PM 10");
 //   dataFile.print(aqi.read(&data)); dataFile.print
    delay(2000);
    dataFile.close();
 void GetBME_Readings(){
  /*****************Get Temp, Pressure and Humidity********************/
  float temp(NAN), hum(NAN), pres(NAN);
  BME280::TempUnit tempUnit(BME280::TempUnit_Celsius);
  BME280::PresUnit presUnit(BME280::PresUnit_Pa);
  bme.read(pres, temp, hum, tempUnit, presUnit);
  preshpa = (pres / 100); //create space for conversion of pascals to hectopascals (hPa) which is more usual measure
  corr_temp = (temp - 0.0); //create space for correction of temperature according to unique sensor validation (will be different for each sensor)
  corr_hum = (hum + 0); //create space for correction of humidity according to unique sensor validation (will be different for each sensor)
  corr_preshpa = (preshpa + 10); //create space for correction of pressure according to unique sensor validation (will be different for each sensor)
  Serial.print(F("Temp: "));
  Serial.print(corr_temp);
  Serial.print("°" + String(tempUnit == BME280::TempUnit_Celsius ? 'C' : 'F'));
  Serial.print(F("\t\tHumidity: "));
  Serial.print(corr_hum);
  Serial.print(F("% RH"));
  Serial.print(F("\t\tPressure: "));
  Serial.print(corr_preshpa);
  Serial.println(F(" hPa"));
 void GetPM_Readings(){
//  /******************GET PM SENSOR DATA*****************************/
  boolean ret = aqi.read(&data);
 Serial.println(ret);
  if (ret) {
  Serial.println(F("AQI reading success"));
//  Serial.println();
  Serial.println(F("---------------------------------------"));
  Serial.println(F("Concentration Units (standard)"));
  Serial.print(F("PM 1.0: ")); Serial.print(data.pm10_standard);
  Serial.print(F("\t\tPM 2.5: ")); Serial.print(data.pm25_standard);
  Serial.print(F("\t\tPM 10: ")); Serial.println(data.pm100_standard);
  Serial.println(F("Concentration Units (environmental)"));
  Serial.print(F("PM 1.0: ")); Serial.print(data.pm10_env);
  Serial.print(F("\t\tPM 2.5: ")); Serial.print(data.pm25_env);
  Serial.print(F("\t\tPM 10: ")); Serial.println(data.pm100_env);
  Serial.print(F("Particles > 0.3um / 0.1L air:")); Serial.println(data.particles_03um);
  Serial.print(F("Particles > 0.5um / 0.1L air:")); Serial.println(data.particles_05um);
  Serial.print(F("Particles > 1.0um / 0.1L air:")); Serial.println(data.particles_10um);
  Serial.print(F("Particles > 2.5um / 0.1L air:")); Serial.println(data.particles_25um);
  Serial.print(F("Particles > 5.0um / 0.1L air:")); Serial.println(data.particles_50um);
  Serial.print(F("Particles > 10 um / 0.1L air:")); Serial.println(data.particles_100um);
 void GetVOC_Readings(){
  /*****************GET VOC**********************/
  a = analogRead(Aout);
  b = digitalRead(Dout);
  Serial.print("D0:");
  Serial.print(b);
  Serial.print("   A0:");
  Serial.println(a);
 void print2SD(){
  /*********STORE DATA TO SD CARD ************/
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  if (dataFile) {
    dataFile.print("\n");
    dataFile.print(rtcy);
    dataFile.print("/");
    dataFile.print(rtcd);
    dataFile.print(rtcm);
    dataFile.print(",");
    dataFile.print(rtchr);
    dataFile.print(":");
    dataFile.print(rtcmin);
    dataFile.print(rtcs);
    dataFile.print(corr_temp);
    dataFile.print(corr_preshpa);
    dataFile.print(corr_hum);
    dataFile.print(b);
    dataFile.print(a);
    dataFile.print(data.particles_03um);
    dataFile.print(data.particles_25um);
    dataFile.print(data.particles_100um);
    dataFile.close();
    delay(10);
    // print to the serial port too:
    //Serial.println(cm);
  // if the file isn't open, pop up an error:
  else {
    Serial.println(F("error opening datalog.csv"));
  delay(20);
void GetRTC_Readings(){
  /*********GET TIME ************/
  time_t p;     //create time object for time and date stamp
  p=RTC.get();  //gets the time from RTC
  Serial.print(year(p));
  Serial.print('/');
  Serial.print(month(p));
  Serial.print('/');
  Serial.print(day(p));
  Serial.print(" (");
//  Serial.print(daysOfTheWeek[dayOfTheWeek(p)]);
  Serial.print(") ");
  Serial.print(hour(p));
  Serial.print(':');
  Serial.print(minute(p));
  Serial.print(':');
  Serial.print(second(p));
 //Serial.println(String(hour(p))+":"+String(minutes(p))+":"+String(second(p)));
  rtcs =  second(p);
  rtcmin = minute(p);
  rtchr = hour(p);
  rtcy = year(p);
  rtcm = month(p);
  rtcd = day(p);
// ***********************End of Code -- you are DONE!*******************************
The comment on the first line is completely wrong. One loop run sleeps for 8 seconds (as SLEEP_8S selects), so the complete loop sleeps for 6128 = 576 seconds so about 9 and a half minutes.
Because you didn't tell us what sleeping time you actually get I guess it's that error you experienced.
Ah my bad dude, it has been changed to 12 minutes which is what it was meant to be . Thank you for that calculation though! even if it is 9 and a half minutes, it seems to add on a minute odd every time it sleeps, unsure why...
The "8 second sleep" uses the watchdog timer, and its frequency can be off by up to about 10%.
If you need accurate sleep times in the range of minutes add an RTC to your project and wait for it's interrupt to wake from sleep.
