EverMore GPS interface
Hi there,
Does anyone have the pin out for a EverMore GM-R307 Gps Module?
Hi there,
I'm very new to arduino so i apologise in advance if i say somthing stupid.
I found an old 12ch GPS from years ago and want to use it along with a compass to make an autonomous boat project. The problem i have is that after going on the evermore website i am still none the wiser as to how to connect the Gps.
GND and +V connections are easy, but which of the other cables from the usb do i use (yellow or green) and can i read data from it as in the parallax gps tutorial?
http://www.arduino.cc/playground/Tutorials/GPS
I've found a few links (below) about the gps itself , but i'm not sure if they are of any help.
http://docs.google.com/viewer?a=v&q=cache:iYp6pQW-gZkJ:gpsd.googlecode.com/files/Emt_GPS_User_Protocol_Rev_D.pdf+Emt+GPS+User+Protocol&hl=en&gl=uk&pid=bl&srcid=ADGEEShokuZoABKmTZAMuM_j7Wz-UW_aVk8aKqYwDD-q1oF0GuIQjsD_qDI86y9u_IGFVTdB1fo75vZiedXJFqrSAZPOyO5f0-97PX_SKLOmcvRNRWO4pLkUNU7jdsrH4iX4NWHtW-Fm&sig=AHIEtbSaRYNmrw5Dp4-6aSX5DRZ80Og7jw
http://www.emt.com.tw/uploadfile/product9_file_GM-R307%20Rev%20B.pdf
If anyone out there can help at all i would be most greatfull.
P.S. See pictures for actual gps, not sure how clear it is from the pictures, but the two boards in the photo stack on top of each other.
http://picasaweb.google.com/lh/photo/DyykSnMZIZUWWIbckuEdOfmv4HKi8Y5IzD__y9peq-k?feat=directlink
http://picasaweb.google.com/lh/photo/BP3MbDWOu5RfJ5BksdxDfvmv4HKi8Y5IzD__y9peq-k?feat=directlink
http://picasaweb.google.com/lh/photo/VQfE0LxIMtQh188-jtk3H_mv4HKi8Y5IzD__y9peq-k?feat=directlink
http://picasaweb.google.com/lh/photo/CTV7VmTeRJ9iDb33qzsdPvmv4HKi8Y5IzD__y9peq-k?feat=directlink
Am trying to use tiny gps and the hardware serial connections on arduino, but not having much luck, any suggestions?
To add a little more info the gps is actualy a Haicom HI-202e usb GPS with an evermore chipset.
I've found the serial to usb chip to be a pl203hxd chip and have got the tx & rx pin out's, but my soldering is rubbish and i'm not very confident about soldering directly to the chip, does anyone know if i can use the data+ and data- off of the usb?
