AWOL:
It's the effing syntax!
C is a block-structured imperative language - after Pascal, what's so hard to learn?
They are both, after all, descendents of Algol (now there I had syntax problems!)
The original creators of C spent about ten years, hampered by small memories and slow CPUs.
In order to compile they had to shuffle a number of tapes!
Must have been a lot of effort.
Assembly is good in some matter it does not put restriction on the programmers creativity, and it does not impose structure where not much creativity exists originally.
Interestingly, using assembler myself for some years, I more and more tended to use techniques also found in C programs/executeable files (for instance I like relocation tables a lot).
So why emulate a compiler manually?
You can really use C similar to assembler but it's different, compared to learn programming by means of C language. It is clearly better in terms of maintainability and readability, some larger assembler sources that I wrote myself are a nightmare to me now after a number of years.
One professional programmer in a course session talked about introduction of IPV6, and he said the reason to introduce the extra address space mainly would be for the reason that it could become wasted
It is true having an operating system based on assembler it would be so much faster and efficient but than there is a wrong bit, wrong place, and the screen goes blank. And also compiled code is less a target for hacking because there is so much overhead.
It is even possible to code assembler on Windows, I tried a little, but then again looked my code, and disposed it off quietly. The disassembly even has become removed from Visual Studio, it was highly useful for me when I learned C++ but that's that, the IDE/debugger also has improved a lot.
There are some older assembler sources around on the net including the Busicom one (Intel 4004), you could take a look at it, and think for yourself what you have and what it is.
One still older source I saw is in a manual for a storage drum, some 16K words capacity, from the 1960s, I calculated it is 52 years old now.
Looking at this source, I am also stunned about computer languages evolution.
