I have developed several issues simultaneously, by the looks of things; I satarted getting messages saying that "boards.txt" was missing, THEN my boards manager just lost my mkr wifi 1010 option under "tools", despite acknowledging that it was still installed(and refusing to allow me to REMOVE, DOWNGRADE or REINSTALL it....), and now my IDE just REFUSES to compile or upload anything, even a blank sketch, to ANY of my boards (I have a couple of UNOs, three NANOs, and a MKR WiFi 1010, if it helps.....?)
I have included my latest error message as hopefully some sort of insight or clue as to the source of my woes....?
someone pleaseplease rescue me here!!
Arduino: 1.8.10 (Windows 7), Board: "Arduino Uno"
D:\ARDUINO\ide\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\ARDUINO\ide\Arduino\hardware -hardware C:\Users\Nav\AppData\Local\Arduino15\packages -tools D:\ARDUINO\ide\Arduino\tools-builder -tools D:\ARDUINO\ide\Arduino\hardware\tools\avr -tools C:\Users\Nav\AppData\Local\Arduino15\packages -built-in-libraries D:\ARDUINO\ide\Arduino\libraries -libraries D:\ARDUINO\ide\sketchbook\libraries -fqbn=arduino:samd:uno -vid-pid=1A86_7523 -ide-version=10810 -build-path C:\Users\Nav\AppData\Local\Temp\arduino_build_44763 -warnings=default -build-cache C:\Users\Nav\AppData\Local\Temp\arduino_cache_535619 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Nav\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\Nav\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose C:\Users\Nav\AppData\Local\Temp\untitled1260009614.tmp\sketch_nov21a\sketch_nov21a.ino
D:\ARDUINO\ide\Arduino\arduino-builder -compile -logger=machine -hardware D:\ARDUINO\ide\Arduino\hardware -hardware C:\Users\Nav\AppData\Local\Arduino15\packages -tools D:\ARDUINO\ide\Arduino\tools-builder -tools D:\ARDUINO\ide\Arduino\hardware\tools\avr -tools C:\Users\Nav\AppData\Local\Arduino15\packages -built-in-libraries D:\ARDUINO\ide\Arduino\libraries -libraries D:\ARDUINO\ide\sketchbook\libraries -fqbn=arduino:samd:uno -vid-pid=1A86_7523 -ide-version=10810 -build-path C:\Users\Nav\AppData\Local\Temp\arduino_build_44763 -warnings=default -build-cache C:\Users\Nav\AppData\Local\Temp\arduino_cache_535619 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Nav\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\Nav\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose C:\Users\Nav\AppData\Local\Temp\untitled1260009614.tmp\sketch_nov21a\sketch_nov21a.ino
Using board 'uno' from platform in folder: C:\Users\Nav\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.4
Using core 'arduino' from platform in folder: C:\Users\Nav\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.4
Detecting libraries used...
recipe.preproc.macros pattern is missing
Error compiling for board Arduino/Genuino Uno.
java.lang.NullPointerException
java.lang.RuntimeException: java.lang.NullPointerException
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$2(ContributionManagerUI.java:175)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.NullPointerException
at cc.arduino.contributions.packages.ContributionInstaller.remove(ContributionInstaller.java:276)
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$2(ContributionManagerUI.java:170)
... 1 more
