everytime various behaviour
I’m new in uC.
I wrote simple program using my own library which should measure time. It should be stop-watch (chronometer?). I don’t know how it’s called in english :).
Almost all is OK, but…
When I want to measure second time, I need to restart arduino. But I have a loop which should (by pressing start button second time) start measure again. But it seems to freeze.
Here is the code:
“main.cpp”
#include <SWtimer.h>
#include <LiquidCrystal.h>
const int numRows = 4;
const int numCols = 20;
int c = 0;
int startPin = 13;
SWTimer timer;
LiquidCrystal lcd(6, 7, 8, 9, 10, 11);
  pinMode(startPin, INPUT);
  analogReference(DEFAULT);
  lcd.begin(numRows, numCols);
  lcd.setCursor(0,0);
  lcd.print("StopWatch v.0.0.1");
// Wait for input signal for start count
  for(;;)
    if(digitalRead(startPin) == HIGH)
      attachInterrupt(0, Timer, RISING);
// Wait to end counting
  while(timer.ended == false)
void Timer()
//if all inputs was "enabled" stop measuring time
  if(timer.readInputs() == true)
    detachInterrupt(0);
//increment time
    timer.incTime();
//show time on display
    for(byte a = 0; a < timer.inputs(); a++)
      lcd.setCursor(0,a+1);
      lcd.print(timer.textTime(a));
My library SWTimer.h is working 100% good. I tested it.
And I have another problem here. If I put this code to loop → “while(timer.ended == false){}” It is working(whole progam - it is counting again and again, allways when I press button on pin 13 (startPin)). But display don’t work - it look’s like “matrix”. There is random changing characters on all display.
lcd.setCursor(0,3);
lcd.print(millis());
Another situation is when I put that code there and when I delete this code from “for(byte a = 0; a < timer.inputs(); a++){}” loop.
If I delete this, display is OK, and I can measure 2nd, 3rd, … time without restarting arduino (but I don’t see time on display :-? )
I don’t understand why it’s one time working and another it isn’t.
Can somebody help me?
PS: sorry for my bad english
I think that it would be helpful to show the SWTimer.h and SWTimer.cpp files, too.
I can post it in evening. I'm now in work. But pssst! :-X ;)
Here is the SWTimer.h and SWTimer.cpp:
SWTimer.h
#ifndef SWTIMER_H
#define SWTIMER_H
#include "WProgram.h"
class SWTimer
public:
  SWTimer();
  ~SWTimer();
  void incTime();
  boolean readInputs(); // scan stop-inputs and write time to "endTime[stop-input number]" if any stop-input is enabled
  unsigned long* stopTime(byte input); //return endTime[] of the selected stop-input
  char* textTime(byte input); // return pointer to text version of current (end time) for selected stop-input with input identifier
  byte inputs(); //return number of stop-inputs
  void setInputs(byte input);
  void disqualify(); //disqualify this competior
  void unfinish(); //competior didn't finish
  void reset(); // reset time for next "competior"
  boolean ended;
private:
  boolean disqualified;
  boolean unfinished;
  byte stopInputs;
  char messageText[13];
  char inputIdentify[8];
  unsigned long time;
  unsigned long endTime[8];
#endif
SWTimer.cpp
#include "SWtimer.h"
SWTimer::SWTimer()
  stopInputs = 1;
  for(byte a = 0; a < 8; a++)
    inputIdentify[a] = a + 48;
  reset();
SWTimer::~SWTimer()
void SWTimer::incTime()
  time++;
boolean SWTimer::readInputs()
  for(byte a = 0; a < stopInputs; a += 2)
    int analog;
    analog = analogRead((a / 2) + 1);
    if(endTime[a] == 0 && analog > 100 && analog < 600)endTime[a] = time;
    if(endTime[a + 1] == 0 && analog > 400 && analog < 900)endTime[a+1] = time;
  ended = true;
  for(byte a = 0; a < stopInputs; a++)
    if(endTime[a] == 0)ended = false;
  return ended;
unsigned long* SWTimer::stopTime(byte input)
  return &endTime[input];
char* SWTimer::textTime(byte input)
  if(endTime[input] == 0)
    sprintf(messageText, "%c: %02d:%02d:%02d", inputIdentify[input], int(time/6000), int((time%6000)/100), int(time%100));
    return messageText;
    sprintf(messageText, "%c: %02d:%02d:%02d", inputIdentify[input], int(endTime[input]/6000), int((endTime[input]%6000)/100), int(endTime[input]%100));
    return messageText;
byte SWTimer::inputs()
  return stopInputs;
void SWTimer::setInputs(byte input)
  stopInputs = input;
void SWTimer::disqualify()
  disqualified = true;
void SWTimer::unfinish()
  unfinished = true;
void SWTimer::reset()
  ended = false;
  disqualified = false;
  unfinished = false;
  time = 0;
  for (byte a = 0; a < stopInputs; a++)
    endTime[a] = 0;
