Example C++ code to communicate with ELEGOO UNO with WiFi camera
I bought the ELEGOO camera robot. This robot is compatible with ARDUINO UNO. For communication between him (web server) and my pc (client) we use WiFi. What I would like to do is set up a TCP/IP communication between my pc (client) and the robot (server - WiFi hotspot) by programming in C++. As library (pc side) for TCP/IP communication in C++, I use ASIO not Boost (standalone). To send command messages from pc to robot, JSON is used. Can you help me write a simple client program in C++ which sends a message/command to the robot using for example the following: {"H": "1", "N": 5, "D1": 1, "D2" : 90}
Write your PC client in Processing
Welcome to Processing! / Processing.org
Coding is "Arduino like" and libraries are available.
I did some UDP stuff years ago and it was straightforward.
Do take the time to review existing projects & examples.
Would you be kind enough to just show me your example, so I can start studying on it. If you want, I can send you the code I wrote, but it can't send the command to the robot, even if my client receives the connection to the server.
tcpip site:processing.org - Google Search
The forum is generally geared to "help forum" rather than do-it or code-writing. Essentially this condenses in your situation to Arduino-code on the uC and to client code on the PC. Thus, 2 parts.
MIT has a product for creating Android smartphone apps and lots of examples if you would rather not utilize Processing.
Beginner Tutorials (mit.edu)
A number of completed projects are searchable for Arduino + AppInventor and may completely eliminate most of the client effort.
But...
  • Write your Arduino code
  • Write your client code
  • Come back with "specific" questions regarding your code
AISO not required for Processing:
Network / Libraries / Processing.org
Processing canned examples:
Examples / Processing.org
Network / Processing.org
String of the message that I have to send in Json format:
{"H": "6", "N" : 5, "D1" : 1, "D2" : 90} -> rotate 90 degree
My code for sending jason message string using ASIO:
asio::io_context context;
asio::error_code ec;
asio::ip::tcp::endpoint endpoint(asio::ip::make_address("192.168.4.1", ec), 100);
asio::ip::tcp::socket socket(context);
socket.connect(endpoint, ec);
if (socket.is_open())
      std::string msg_j = "{"H": "1", "N": 5, "D1": 1, "D2": 90}";
      socket.write_some(asio::buffer(msg_j, msg_j.size()), ec);
      asio::streambuf receive_buffer;
      asio::read(socket, receive_buffer, asio::transfer_all(), ec);
      if (ec && ec != asio::error::eof)
	    std::cout << "receive failed: " << ec.message() << std::endl;
            return 1;
	   const char* data = asio::buffer_cast<const char*>(receive_buffer.data());
	   std::cout << "Received: " << data << std::endl;
I'm not getting any response from the server-robot. The problem may be that the jason string is formatted as std::string. It is here that I would like some help on how to transform it into the correct jason and then into a string format to be able to give it to ASIO to send it.
Have you run your JSON through the online validator?
JSON Online Validator and Formatter - JSON Lint
"Have to" or "want to"? Such simple command structure could easily be handled in ASCII packets.
JSON is extreamly simple to fool:
Serial output directly into NodeRED - Arduino for STM32 (stm32duino.com)
I entered the string in the validator you indicated and this is the result
	"H": "1",
	"N": 5,
	"D1": 1,
	"D2": 90
So, not a JSON format issue, it would seem.
Have you added serial.Print() statements to assist in diags?
I tried running the Arduino IDE as well to see if it gets the message, but it doesn't display anything...
When I get into such a predicament, I usually stop, write very simple code with diag statements solely for testing. If the JSON is not being parsed, maybe try a different library or with something this simple, just send comma-delimited data and do your own parsing.
Hummm, on the Arduino server side, I don't want to touch the web server code that ELEGOO wrote, otherwise I risk having nothing working. At most I could try to write a client/server program on the pc using ASIO. But I've done this before and it works great.
