I have got an example code to send CAN messages from Here. However when I try to compile it, it says: cannot declare variable 'CAN' to be abstract type 'MCP_CAN'. I have included the library from github etc and even rolled back the IDE to 1.8.3 which it was tested on.
Is there anything else I could try?
// demo: CAN-BUS Shield, send data
#include <mcp_can.h>
#include <SPI.h>
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 9;
MCP_CAN CAN(SPI_CS_PIN); // Set CS pin
START_INIT:
if(CAN_OK == CAN.begin(CAN_500KBPS)) // init can bus : baudrate = 500k
Serial.println("CAN BUS Shield init ok!");
Serial.println("CAN BUS Shield init fail");
Serial.println("Init CAN BUS Shield again");
delay(100);
goto START_INIT;
unsigned char stmp[8] = {0, 1, 2, 3, 4, 5, 6, 7};
// send data: id = 0x00, standrad frame, data len = 8, stmp: data buf
CAN.sendMsgBuf(0x00, 0, 8, stmp);
delay(100); // send data per 100ms
END FILE
Thanks all, I've compiled the code below fine now and transmitted first signal !! Library here
// CAN Send Example
#include <SPI.h>
MCP_CAN CAN0(10); // Set CS to pin 10
// Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK) Serial.println("MCP2515 Initialized Successfully!");
else Serial.println("Error Initializing MCP2515...");
CAN0.setMode(MCP_NORMAL); // Change to normal mode to allow messages to be transmitted
byte data[8] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07};
// send data: ID = 0x100, Standard CAN Frame, Data length = 8 bytes, 'data' = array of data bytes to send
byte sndStat = CAN0.sendMsgBuf(0x100, 0, 8, data);
if(sndStat == CAN_OK){
Serial.println("Message Sent Successfully!");
Serial.println("Error Sending Message...");
END FILE
