This is the code. Sorry for the large size but its a rather large project. I have deleted most of the code as its way to big to post. I just included the header part, Setup() and the function for NTP
So the issue is when I try to use the NTP code (the built in arduino example sketch) within this project I get "No response from NTP".
I dont believe its network setting as if I use this the same networking settings with the example push NTP sketch it works 100% ok.
It has to be something to to do with the fact I am running a webserver as well, possibly socket binding. Note commenting out the server.begin() does not make the NTP work, I have tried this.
Also if anyone has suggestions on shaving some size of this project I would be quite happy. I know theres lots of room for improvements here.
//Push Scheduler Control Centre.
//By Jasper Parker (2013)
//Included Libraries
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Time.h>
#include <TimeAlarms.h>
#include <EEPROM.h>
#include <Wire.h>
#include <DS1307RTC.h>
// NTP stuff
IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov
const int timeZone = 8; // Perth
EthernetUDP Udp;
unsigned int localPort = 8888; // local port to listen for UDP packets
//Set a Mac Address
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
//Set the IP address from EEPROM memory
byte ip[4] = {
EEPROM.read(4), EEPROM.read(5), EEPROM.read(6), EEPROM.read(7) };
//byte ip[4] = { 192, 168, 1, 125 };
IPAddress gateway( 192,168,1,1 );
IPAddress subnet( 255,255,255,0 );
//Create server and client instances
EthernetClient client;
EthernetServer server(80);
//Some required Boolean variables
boolean macro1HasRun = false;
boolean macro2HasRun = false;
boolean macro3HasRun = false;
boolean macro4HasRun = false;
boolean macro5HasRun = false;
boolean macro6HasRun = false;
boolean macro7HasRun = false;
boolean macro8HasRun = false;
boolean macro9HasRun = false;
boolean macro10HasRun = false;
boolean sleepTimerKill = false;
//boolean awaitingTime = true;
int prevDisplay;
//Old System Time method
//int sHours,sMinutes;
//Arrays to store current selected schedule days
char printDays[100];
//Sleep Timer variabkles
byte sleepTimer, sleepTimerMacro;
//Scheduling Variables
byte tHours1,tMinutes1,macro1,tHours2,tMinutes2,macro2,tHours3,tMinutes3,macro3,tHours4,tMinutes4,macro4,tHours5,
tMi
//Day collection
byte macro1DayM,macro1DayT,macro1DayW,macro1DayTh,macro1DayF,macro1DayS,macro1DaySu,macro2DayM,macro2DayT,macro2DayW,macro2DayTh,macro2DayF,macro2DayS,macro2DaySu,
byte pushIP1,pushIP2,pushIP3,pushIP4;
byte arduinoIP1,arduinoIP2,arduinoIP3,arduinoIP4;
//Set Push IP based on EEPROM memory
byte push[4] = {
EEPROM.read(0), EEPROM.read(1), EEPROM.read(2), EEPROM.read(3) };
char buffer[16];
//Requiered HTTP request for sending commands to Push
String pushMacro = "GET /bwc.xml?bwc=bwc:macro:";
//If no IP address has been writtin to EEPROM on this device set to default address
if((EEPROM.read(4))==255) {
byte ip[4] = {
192,168,1,125 };
//Sets time
//setSyncProvider(RTC.get);
//setSyncInterval(600);
//Initilise network things
Wire.begin();
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
Udp.begin(localPort);
//System has booted
Serial.println(F("System Booted"));
Serial.println("waiting for sync");
setSyncProvider(getNtpTime);
/*-------- NTP code ----------*/
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBufferT[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
while (Udp.parsePacket() > 0) ; // discard any previously received packets
Serial.println("Transmit NTP Request");
sendNTPpacket(timeServer);
uint32_t beginWait = millis();
while (millis() - beginWait < 1500) {
int size = Udp.parsePacket();
if (size >= NTP_PACKET_SIZE) {
Serial.println("Receive NTP Response");
Udp.read(packetBufferT, NTP_PACKET_SIZE); // read packet into the buffer
unsigned long secsSince1900;
// convert four bytes starting at location 40 to a long integer
secsSince1900 = (unsigned long)packetBufferT[40] << 24;
secsSince1900 |= (unsigned long)packetBufferT[41] << 16;
secsSince1900 |= (unsigned long)packetBufferT[42] << 8;
secsSince1900 |= (unsigned long)packetBufferT[43];
return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
Serial.println("No NTP Response");
return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
void sendNTPpacket(IPAddress &address)
// set all bytes in the buffer to 0
memset(packetBufferT, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBufferT[0] = 0b11100011; // LI, Version, Mode
packetBufferT[1] = 0; // Stratum, or type of clock
packetBufferT[2] = 6; // Polling Interval
packetBufferT[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBufferT[12] = 49;
packetBufferT[13] = 0x4E;
packetBufferT[14] = 49;
packetBufferT[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(packetBufferT, NTP_PACKET_SIZE);
Udp.endPacket();
