Example Programm dosn´t find its own library
Im trying to test the LSM303DLHC.
I installed the library "Adafruit LSM303DLHC", then opended the Example-Programm "magsensor" but it can´t find it´s own librarys.
Arduino: 1.8.9 (Windows 10), Board: "Arduino Leonardo"
magsensor:2:29: error: Adafruit_Sensor.h: No such file or directory
compilation terminated.
exit status 1
I don´t know, what to do, it would be very nice, if someone replies, thank you.
exit status 1
Did you install this library?
Do you mean "Adafruit_Sensor.h"? Yes, I used the Example Programm out of the Library it´s Folder.
You're using the example sketch from the Adafruit LSM303DLHC library. That library has a dependency on the Adafruit Unified Sensor library. So you need to install that library as well.
This is a fairly common thing in Arduino libraries. Just as our sketches benefit from using shared code in libraries, libraries can benefit from using shared code from other libraries. Ideally, the library author will clearly document the dependencies, as Adafruit usually does. Other times, the library author won't have bothered to write that documentation and you'll need to go on a scavenger hunt for the library dependencies.
Thanks a lot for your very detailed answer, now it works!
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
and next version of IDE will handle it
source: Redirecting to Google Groups
