example setCursor in LiquidCristal
Hello,
I was studying the example “setCursor” and i didn’t understand the code. Although it works, the logic behind it was not very clear. I came up with another version which in my mind will do better. Especially for the beginners in Arduino code (which i am) the examples are an important introduction. They need to be as simple as can be.
The original code is:
 // include the library code:
#include <LiquidCrystal.h>
// these constants won't change.  But you can change the size of
// your LCD using them:
const int numRows = 2;
const int numCols = 16;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(numCols,numRows);
  // loop from ASCII 'a' to ASCII 'z':
  for (int thisLetter = 'a'; thisLetter <= 'z'; thisLetter++) {
    // loop over the columns:
    for (int thisCol = 0; thisCol < numRows; thisCol++) {
      // loop over the rows:
      for (int thisRow = 0; thisRow < numCols; thisRow++) {
        // set the cursor position:
        lcd.setCursor(thisRow,thisCol);
        // print the letter:
        lcd.write(thisLetter);
        delay(200);
Look at the statement " lcd.setCursor(thisRow,thisCol);"
row and column are in the wrong place.
My version is:
    for (int thisRow = 0; thisRow < numRows; thisRow++) {
      for (int thisCol = 0; thisCol < numCols; thisCol++) {
        lcd.setCursor(thisCol,thisRow);
        delay(200);
I hope the example in the Arduino software can be changed.
Greetings to all, Jan.
I Janz, good point! I believe that you must post this question, not in this section, but in: Development: Suggestions for the Arduino Project, look to the description of this section: "What do you think should be improved, features for the hard/software, bugs you found".
Regards.
This seems to be a duplicate/cross-post of this thread: http://forum.arduino.cc/index.php?topic=245426.0
