Example sketch IRremote ReceiveDump not working
Here is an updated version of the sketch. It lets you change the Adjust value, or just run it again, without having to reset.
// This interprets incoming IR from a remote control as raw data.
// An IR receiver module should be connected to D8.
// The Adjust variable adjusts time between On and Off periods since
//   receivers may turn on faster than they turn off, or vice verse.
// Results will include any repeats.
// The displayed numbers alternate between transmitting and idle states.
const int maxEntries = 300;
unsigned int bitTime[maxEntries];                 // uSeconds in each state
bool active [maxEntries];                         // transmitting or idle
int Adjust = 15, newAdjust;                       // receiver turn on, turn off times not the same
const byte recvPin = 8;
volatile unsigned int timerMSB, capMSB;           // third byte of 24-bit timer (timer1 = 1st two)
volatile bool Capture;                            // a state change has occurred, and time captured
unsigned long timerLO, timerHI, newTime, prevTime;
int i, j, k;
bool activeLO;                                    // receiver output is low when receiving carrier
bool activeNow = false;
bool Waiting, Start;
  Serial.begin (115200);
  pinMode(recvPin, INPUT);
  activeLO = true;                                // assume no transmission now
  if (!digitalRead(recvPin)) activeLO = false;
  cli();
  TIMSK0 = 0;                                     // Disable Timer0 interrupts (millis)
  TCCR0A = 0;
  TCCR0B = 0;
  TIFR0  = 0xFF;
  TCCR1A = 0;                                     // set up Timer1
  TCCR1B = 0;
  TCCR1C = 0;
  TCNT0  = 0;                                     // clear Timer1
  TIFR1  = 0xFF;                                  // clear flags
  TIMSK1 = 0b00100001;                            // enable capture and overflow interrupt (GPS)
  TCCR1A = 0b00000000;                            // Normal mode, no output, WGM #0
  sei();
  Start = true;
  if(Start) {                                     // initialize everything on start or restart
    Start = false;
    i = 0;
    j = 1;
    Waiting = true;
    Capture = false;
    activeNow = false;
    cli();
    if (activeLO) TCCR1B = 0b00000010;      // falling edge capture, timer1 on, prescale /8
    else TCCR1B = 0b01000010;               // rising edge capture, timer1 on, prescale /8
    TIFR1  = 0xFF;
    sei();
    Serial.print("Adjust = "); Serial.println(Adjust);
    Serial.println("Enter new Adjust value, or [Enter]");
    while (!Serial.available());
    newAdjust = Serial.parseInt(SKIP_NONE);
    if (newAdjust) Adjust = newAdjust;
    while(Serial.available()) Serial.read();
    Serial.println("Waiting for IR transmission...");
  if (Waiting) {                                  // keep MSB cleared
    if (timerMSB) {
      cli();
      timerMSB = 0;
      sei();
  if(Capture) {                                   // input has changed state
    Capture = false;
    Waiting = false;
    timerLO = ICR1;                               // read timer values
    timerHI = capMSB;
    newTime = ((timerHI << 16) + timerLO +1) >> 1;  // combine timer counts to one long value
    if (i) {                                      // skip i=0
      bitTime[i] = newTime - prevTime;            // collect duration and activity state
      active[i] = activeNow;
    prevTime = newTime;                           // prepare for next state change
    activeNow = !activeNow;
    TCCR1B ^= 0b01000000;                         // capture on opposite edge
    i++;
  if ((timerMSB > 40) || (i > maxEntries)) {
    TCCR1B &= 0xFE;                               // stop Timer1 clock
    for (k = 1; k < i; k++) {                     // adjust on (Mark) and off (Space) times
      if (active[k]) bitTime[k] -= Adjust;
      else bitTime[k] += Adjust;
    Serial.println();
// This has been modified to remove the minus signs
   while (j < i) {
      for (k = 0; k < 8; k++) {
        Serial.print (bitTime[j]);
        j++;
        if (j == i) break;
        else Serial.print (", ");
      Serial.println();
    Serial.println();
    Start = true;
ISR(TIMER1_CAPT_vect) {
  capMSB = timerMSB;                              // also capture MSB at same instant
  Capture = true;
ISR(TIMER1_OVF_vect) {
  timerMSB++;                                     // increment MSB on overflow
