Example with pointers works: Difference between * and no * at pointers?
Hello Folks,
I'm currently reading a basic c++ book and tried some example with pointers.
This example works perfect but I don't understand the explanation
In the book stands, that the variable with * (asteriks) points to the value and without the * asteriks to the address of the pointer. But with this fact, my example should print the addresses not the values?
int y[10] = {9, 8, 7, 6, 5, 4, 3, 2, 1, 0};
int x[11] = {9, 8, 0,-1};
void f(int *a, size_t n){
   for ( int i = 0; i < n; i++ )
       Serial.println(a[i]);
    Serial.println("---------------------");
  Serial.println("Hello, ESP32!");
  f(x, 10);
  f(x, 4);
  delay(10); // this speeds up the simulation
printed output
Hello, ESP32!
9
8
0
-1
0
0
0
0
0
0
9
8
0
-1
To print the address of a you should print it itself, not the a[i]
try this:
  Serial.print("Address of the a: ");
  Serial.println((uint32_t) a, HEX);
  Serial.print("Values of the a[]: ");
consider
f: 0x116d
  0, 0x116     9
  1, 0x118     8
  2, 0x11a     7
  3, 0x11c     6
  4, 0x11e     5
  5, 0x120     4
  6, 0x122     3
  7, 0x124     2
  8, 0x126     1
  9, 0x128     0
f: 0x100d
  0, 0x100     9
  1, 0x102     8
  2, 0x104     0
  3, 0x106    -1
  4, 0x108     0
  5, 0x10a     0
  6, 0x10c     0
  7, 0x10e     0
  8, 0x110     0
  9, 0x112     0
 10, 0x114     0
char s [80];
void f (
    int     *a,
    size_t   n )
    sprintf (s, "%s: %pd", __func__, a);
    Serial.println (s);
    for (unsigned i = 0; i < n; i++ ) {
        sprintf (s, " %2d, %p  %4d", i, & a[i], a [i]);
        Serial.println (s);
void setup ()
    Serial.begin (9600);
    f (y, 10);
    f (x, 11);
void loop ()
Yes. It is confusing. In the context of pointers, '*' can mean either a derefencing operator or a pointer declaration depending on where you see it.
int x[11] = {9, 8, 0,-1} ; Simple array declaration partially initialised.
void f(int *a, size_t n){ . . . declares a as a pointer to an int or, as in this case, the start of an array of the int type.
Serial.print( *x ); will print the first element in the array x[ ], that is the value 9, by dereferencing the pointer to its address.
Serial.print( *(x+1) ); will print the next element in the array x[ ] by dereferencing the pointer expression etc.
a[n] means the same thing as *(a+n)
This is where you have to be alert if you try to put concrete figures into the expression.
If, for example, a is at address 1024 and n is 3, the expression a+n does not necessarily result in 1027. The '+' operator is overloaded and has a new meaning. The expression is to be interpreted as a + (size of a data item) * n. In the case of a 2 byte integer a+n give 1030.
1. Given:
byte y = 0x23;
(1) In the above declaration, the variable y refers to the 8-bit content (byte) of a RAM location of the ATmega328P MCU of the UNO Board. The range of the RAM space is: 0x0100 - 0x08EF + Stack Space (Fig-1).
ATmega328PRAMSpace
Figure-1:
(2) The symbolic name of the RAM location that holds the value of y is: Mx.
(3) Every memory location of Fig-1 has 16-bit (actually it is 12-bit) numerical value called address.
(4) The value of the address of location Mx can be known by executing the following codes:
byte *ptr; //ptr is pointer variable; it can hold address of a byte-organized memory location
ptr = &y;   //address of Mx which holds content of y is passed to ptr variable
Serial.print((uint16_t)ptr, HEX); shows 16-bit address value of Mx location; 0x08FB
2. Given:
int myData[] = {8, 9, 258, -45};
(1) In the above declaration, the array name myData (by design) contains the base address (the address of the first byte of a word (16-bit) organized array); whereas, myData[0] refers to the first byte of the M0 location (Fig-2).
ArrayWordOrganized
Figure-2:
(2) The value of the address of location M0 can be known by executing the following codes:
  int *ptr;  //ptr is pointer variable; holds base address of a word-organized memory space
  ptr = myData; //ptr holds base address of array
  Serial.println((uint16_t)ptr, HEX); //shows: 0x0100; address of M0
(3) The value of the address of location M3 can be known by executing the following codes:
  ptr = ptr + 3;  //advance pointer variable to point location M3
  Serial.println((uint16_t)ptr, HEX); //shows: 0x0106 address of M3
  Serial.println((uint16_t)*ptr, HEX); //shows: 0xFFD3;
  //data from 16-bit wide location  M3 whose base address is in poniter variable ptr
Yes! They refer to the content of same memory location as verified in the context of the following declaration:
ArrayWordOrganized
Figure-1:
  int *ptr;
  Serial.println((uint16_t)myData[3], HEX); //shows: FFD3
  Serial.print((uint16_t)*(myData + 3), HEX); //shows: FFD3
