Examples of BigNumber library (Power_of_E) only works for integer numbers
Is it possible that Examples of BigNumber library like (Power_of_E) can be implemented for fractional numbers ?
I had try to find power of E for fractional numbers using big number library, but during calculations code only consider integer part of given value. Following is the code that is the same as example given in BigNumber library..
// BigNumber test: calculate power of E
#include "BigNumber.h"
BigNumber ePower (BigNumber x)
  // if x > 1 halve it and square the result
  if (x > 1)
    BigNumber e = ePower (x / BigNumber (2));
    return e * e;
    }  // end of x > 1
  // some big numbers
  BigNumber n = 1, e = 1, t = 1;
  int i = 1;
  BigNumber E;
  do
    E = e;
    n *= i++;  // n is i factorial
    t *= x;    // t is x^i
    e += t / n;
  } while (e != E);
  return e;
  } // end of function ePower
void setup ()
  Serial.begin (115200);
  Serial.println ();
  Serial.println ();
  BigNumber::begin (65);   // max around 65 on the Uno for a power of 5
   Serial.println ("Answer of e^5 is");
  Serial.println (ePower (5));  // e  ^ 5
  Serial.println ("Answer of e^5.5 is");
  Serial.println (ePower (5.5));  // e  ^ 5.5
  Serial.println ("Answer of e^-8 is");
  Serial.println (ePower (-8));  // e  ^ -8
  Serial.println ("Answer of e^-8.5 is");
  Serial.println (ePower (-8.5));  // e  ^ -8.5
} // end of setup
void loop () { }
Output of the given code is
***OUTPUT***** Answer of e^5 is
148.41315910257660
Answer of e^5.5 is
148.41315910257660
Answer of e^-8 is
0.0003354626279025
Answer of e^-8.5 is
0.0003354626279025
*****OUTPUT*********
That is same for integer and floating point values
Is it possible to make the code generalized that can work both for integer and fractional point values ?
Even Multiplication of integer number and a fractional point number gives wrong answer.
// BigNumber test: multiplication
void setup ()
  Serial.println ();
  Serial.println ();
  BigNumber::begin ();  // initialize library
  // test multiplication
  BigNumber a = "12345";
  BigNumber b = "0.555";
  BigNumber c = a * b;
  Serial.println(" Multiplication of a and b is = ");
  Serial.println (c);
}  // end of setup
void loop () { }
gives output as
***OUTPUT******
Multiplication of a and b is = 0
